Yo. Time to begin operation: catch up on a month!
WTAC snaps
and I've started working on sets again. Spent a while on this one last night cleaning up the car, had a stack of reflections and shit going on. not to mention some horrible colour balance thanks to car park tungstens.
  • Replies 96
Posted Images
^ Absolutely fantastic pics Matboy.
Only thing I would change in that last S15 pic is the shade of tyre colour. Just a curve adjustment on the black to make it a tad darker and blend in sexy with the shadows.
But who am I to give advice to the pro's. Love your work as always.
dude hope you holding on to something when you got your legs over the edge lol. Nice shots man :)
Nice lighting dan!! cool shot.
Flat out lately. Going to have no life till end of December. Anyone want to come assist me on some shoots (specially my pre-wedding shoots as I need someone to hold my lights etc).
Some randoms..
From a e-shoot:
Two light setup. Einstein in BD (gelled to match sunset), and 430exii as rim light (not gelled). Hmm time to upgrade to 600exii and use its gel holder feature lol :P
One light setup. Einstein in BD boomed way up high.
Slow shutter speed to bring in more ambient light. Very quick shot of the couple before reception started.
Up in Newcastle.
Sun as rim light.
Here you go another natural light shot.
Something different from me:
Purchased a macro lens. so just testing it out on my corals:
Plenty more pics.. But that will do for now.
Actually one more..
An amazing belly dancer at last nights event. Cropped head and the other lady off to the right (cant show faces just yet).
But half way thru the act she was balancing a sword on her belly and head.
Two light setup again.
Some cool shots up there guys.
Rest can be seen: http://richardgraing...le-and-rowan/22 if interested
Sup man.. With this shot get the groom to kiss around her neck area. Get them closer and ask her to bring her chin up. Will look much better (just my opinion).
Otherwise nice work.
Edited by siddr20
Well guys my effort this month hasn't been nearly the grade that you folks do. Please feel free to give me some tips and pointers.
I went to WTAC this year with the focus on getting a few good shots. I found the night photography/panning especially tricky to get the settings right. I figured the only way to learn is to keep working at it until I find some things that start to work. My panning skills are nearly up to snuff with you fellas so at night every little wobble really throws the focus.
I feel like I learned a bit but wow - really get an appreciation for the guys that can get those extra extra clear night panning shots.
Eric, come find me next time you've got your camera and there's moving targets around. :)
I was getting some sharp shots at 1/5th during the drifting! Still, looked like balls on my crappy sensor though. Oh well, almost upgrade time!
So I entered the Photo5 comp with this. The theme was Wind.
(FACEBOOK COMPRESSION)
Edited by MaTBoY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
