Hey guys, I need help with a re-occuring problem that has been plaging me for a while now. It all started when i added an exhaust side cam gear to my r33 and a retune of my unichip. The car made 210rwkws, up from 195 it previously had without cam gear. But then a few days later, the car started to run terriblely. I would accelerate and I could feel the power going up and down. I had it re dynoed at a Dyno day where this proved my concern showing only 200rwkws, but the power curve was terrible goin up and down +-15rwkws all the way to redline. So i thought it was AFM maxing out, hence pulling timing as Unichip still retains stock ecu.
I measured AFM voltage while going for a drive, indeed it was maxed out, 5.05v. So i turned down boost from 14psi to 11psi. The car ran a bit better, but was still running crap comared to when it was tuned at 195 with 14psi (ie without cam gear).
This was about 2 months ago, and since then the car has gotten progressively worse. The car has developed a power jerk cut out running only 11psi. This has never happened, even when running at 14psi and 195kws. I assume the car is makin alot less now cos it feels terrible, like the engine doesnt wanting to rev out. So thinkin it was an bad tune with the ECU, i pulled out the Unichip, and reset the stock ecu.
Then i went for a burn, the car felt good at 8psi. a lot stronger then what it did with 11psi and Unichip. But then 1 day after this, the car is developing the power cut out agian at 11psi. I have no idea whats happening. The stock ECU never ever did this sort of thing before so why now. The car also feels that it has gotten progressively worse since resetting it.
Im at the point of being so frustrated. Is it somethint to do with the camgear. Its set to -3deg, but since being installed is nothin but trouble. Also the problems started after the tuner changed by iridium plugs to platnium and gapped at 0.7mm. I have also changed them back to Copper NGks at 0.8mms and the car is still the same.
Any suggestions that could help me would be appreciated. Like i said the car has never been like this before, so i have no idea where to start.
THanks in advanced.
Dean
https://www.sau.com.au/forums/topic/40613-power-cuts-again-pls-help/
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
