http://www.ebay.com.au/itm/130696551537?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
hey fellas this is cheap as chips so i thought id buy one, any one used it before? and can you recommend if i should run it with the waste-gate/ turbo separator in or out? what do you think boys?
https://www.sau.com.au/forums/topic/406130-dump-pipe-advice/
  • Replies 66
Posted Images
If you were to use it, the separator is an essential part. There is no point having a split dump unless the flows are actually split, and the only way to do that is to have the separator in there. This design is "fabricated" in that the separator is attached with fasteners. Others are welded.
But even if you were to want to use a split dump, you wouldn't buy one of these because the short ones are shite. The only ones worth considering are the ones that are a full dump and front pipe unit in one, and the split is dropped back in a long way down.
right now i understand! well ive got a spare few bucks so im gonna give it a go, and ill let you know how it goes, my current one has a leak on the gasket so, for the price of the gasket might aswell swap it for this. cheers blokes!
Just keep an eye on your boost gauge, you don't want to blow an engine, or the turbo for that matter...
will do, im installing a r34 smic and rb20 actuator at the same time, so i planned on giving most of my attention to the boost gauge on the first drive! haha!
http://www.ebay.com....984.m1497.l2649
read the words then keep your smart arse comments to your self. the advice i was after was should the separator be kept in or not, not if i should buy it as i stated i have already bought it.
but on a lighter note, thanks for the help people!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
