Hey people,
Hoping someone can help me out.
When starting up my car I have noticed a rattle coming from the gearbox.
It is a bit of a weird description but it sounds kind of like a paper clip or a small coin in the dryer.
After it warms up it gets a lot quieter but is still there. It is not the input shaft bearing as the noise is there all the time regardless of when the clutch is in or out.
I have never heard it from inside the car though, you can only really hear it from outside.
Also at really slow speeds like driving around car parks and pulling out of the drive way letting the clutch out there seems to be a whining grind but it is not all the time.
I know the clutch is pretty heavy duty however I am not sure what it is as the guy I bought the car off told me he couldn't remember what it was but he paid around 2500 to have it put in and it is very heavy.
I have no problems with gear shifts and it never slips.
If anyone had some ideas about what it could be I would appreciate it.
Cheers,
Andy
https://www.sau.com.au/forums/topic/406158-r34-gtt-gearbox-rattle/
The thrust bearing is the one that changes sound with the clutch in or out. I myself have a similar noise from the gearbox, but ive got a damaged second gear syncro and the input shaft bearing is going.Take it to a specialist if your worried by the noise, they should pick up what it is. Otherwise leave it, if you drive it sedately it may not get any worse, or if like me you drive it hard you may worsen it, 8 months on im pulling my box back out to get it rebuilt. Goodluck
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
