No is the answer to almost all your questions.
No, you can't use mail.gmail.com as the outgoing mail server on your bigpond account.
No, you can't send as your bigpond address from a Gmail account via the iPhone interface, although you should be able to do it using the Gmail app (there is an official one) or the Gmail web interface.
By far your best option is to setup a Gmail or Google Apps account, and check your Bigpond account using this, and migrate across to the Google account.
Either that or have this conversation with Telstra, and see if they have a config that will work with other networks.
Wouldn't the easiest way to send an email from your Bigpond account while OS be to simply log in via your browser, in the same way you would log into hotmail, etc. sure it won't be as nice as using the app, but it will get the job done.
create a gmail account. in a full version browser (on your pc/mac) go to settings >> accounts and import, in gmail. set up your bigpond account in there.
gmail will automatically retrieve any of your bigpond emails sitting on the bigpond mail server.
set up your bigpond email as an alias in gmail. select 'reply from the same address email was sent to'
stick with the default settings for most things.
send and receive mail from anywhere anytime using gmail.
install gmail to your aidsphone.
google this shit. there are step by step guides. its simple. should take you 10 minutes.
i went further, and had my mail directly forward to gmail, and created filters whereby everything is labelled and sorted.
this removes the random refresh times you get when using non-gmail addresses in gmail.
but thats another story.
OR
do what marc said.
Edited by Munkyb0y
Are you using your SIM from oz or have you bought a SIM from there?
Unfortunately with bigpond, as Ryan mentioned, you cannot send emails, only receive them and creating a gmail account is the easiest way around it.
However,
There is one other way around it which can sometimes work. You'll need to make the outgoing server that of whichever network you are using overseas eg. If your phone is using a Vodafone server, change your outgoing server to smtp.vodafone.net.au (being overseas, the "net.au" bit will be different). Some networks like Optus change the "smtp" bit and use mail.optusnet.com.au.
Again, this may or may not work.
Bigpond is one of those ISPs that are dicky to use when you're overseas.
http://www.wiseinternet.com.au/support/Outgoing-Mail-Server-Settings.aspx
However,
http://www.wiseinter...r-Settings.aspx
politicians seem to have no troubles racking up huge phone bills overseas
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
