Yeah, a mate of mine just sold his white mint 2011 for $125k yesterday to fund his Audi R8 project. His was totally unencumbered (owned it outright), with 14,xxx kms on the clock... For sure the cars not owing $ and with owners on a mission will go cheaper - I remember when I was searching for my GT-R, most of the 2nd hand 2009's and 2010's I checked out at the time had more $$'s encumbered/owing than the carsales list price, and the owners I contacted sounded like drug dealers...... I still can't complain getting a new 2010 for $138k though...
I only owe about $30k on mine, and that'll be gone well before the warranty expires.
2012 for 125K - that's a good deal.
I've been following the prices a bit too, and yeah I agree with many posters, the 09's advertised for 110k-115K are simply not moving.
I always compare the R35's with comparably priced, when new, M3 or a C63. I know you cannot compare the performance, but a nice, mint condition 08' M3 manual goes for high 70's.......and I would say the demand for an M3 would be higher then for the R35.
Only fanboi's like myself will go for the R35, and I'm convinced there are more badge chasers in this world then GT-R lovers.
  • Replies 60
here it is. in very good nick inside and out once I got rid of the swirls.
Plates are going. Anyone interested in Vic plates?
That is stunning! Do like the black. I have only ever seen 1 GTR in person, there is a grey one in my town that gets around every now and then. I LOVE them, hopefully in a few years time i will be able to afford one :)
  • 10 months later...
I know, I know - pulling an ancient thread out, but simply revisiting it after nearly 12 months.....and..shock, horror looks like ADM-09 prices haven't dropped like a stone. Cheapest 09's advertised for 104K. Looks like Wardski was correct and the 200K price for new ones is keeping depreciation mild.
There was a sparkling silver 09 premium for sale in Perth not long ago ,went for $85000 had 25000 kms on it ,had a full service history ,4 new tyres it was a very clean example,I took pics for my mate to buy it but he decided to go back to an m3 again.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
