Hey guys, i was wondering how will an 18x9.5 +20 sit on an R34 GTT im hopeless at the whole offset thing and i cant find much info on 34's and offset etc
if you got pics can you post size and offset too
Any help would be appreciated
Thanks
https://www.sau.com.au/forums/topic/406179-r34-gt-t-offset/
Ride height? Guards rolled? Adjustable arms?
IMO 9.5 + 20 is perfect with a 235 stretched on them with the car low and the guards rolled. If you dont have that done then your gonna have a bad time.
https://www.sau.com.au/forums/topic/406179-r34-gt-t-offset/#findComment-6482266
ride height is to be determined but yeah slammed, and just picked up a set of 18x9.5 +30 i think they are..?
havnt had a chance to roll the guards, but then again no rush to do it cause coilovers are on the way from japan
https://www.sau.com.au/forums/topic/406179-r34-gt-t-offset/#findComment-6483494
9.5+15 will be tight on the back, i used to run these then went to a +20 and its perfect. The front you may get some rubbing on the guard lip turning, but it all comes down to aligment and ride height. Will look mint none the less anyway!
https://www.sau.com.au/forums/topic/406179-r34-gt-t-offset/#findComment-6485848
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
