not that I know of. RB26 always remained the same AFAIK. the way to tell was the lil buldge on the left hand side of the cam cover, I've never seen one on a RB26 even off an R34.
heh...
I think every single person (with the exception of the thread starter possibly) has mixed up Variable VALVE Timing (VVT), Variable Valve Timing and Lift (VVTL) and Variable CAM Timing (VCT)
HKS do make a VCT cam kit but it is very expensive (Andrew may dig it though!) - it was priced perhaps a fair amount more than say Jun cams.
I have not seen any car with it though besides HKS's own demo car and well... that's hardly independent.
If you believe the HKS spiel, response is greatly improved.
T.
well that pic is from Option mag, the car using it is a race car in Tsukuba. Basically the whole story was on V-Cams in this R32 GTR. Not tuned by HKS, was running HKS GT2540x2 Apparently it greatly improves the response of the car out of corners etc.
Its on Page 82 Option2 issue Jan 2004
What's the difference between VCT and VVT? Does one just change the duration and the other the opening time?
BTW I made a thread about this a while back but noone could help - does Nissan make ANY engines with variable timing, duration and lift? The SR20VET is the closest I've seen, but it doesn't seem to control the duration from what I can tell.
Cheers,
Michael
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
    • Yes, a plan for non-action is always my first sort of plan! I'm happy to see what falls out of invision's update. I had been having some thoughts on what to do with this the other day and they all seem to have fled my memory, after various solar panel induced traumas, squeaking suspension sphericals, etc etc, over the last little bit. I'll try and recall what I had in mind and make sure that I put it into print in some form before the Alzheimer's strikes again.
    • The ability to have both a 5500 stall for launching, and a regular lockup for every other scenario is pretty sweet. Does it actually work well like that though in the real world? Would it hold up to track use and otherwise you'd never know you had a stall converter in it? If so, that's awesome
