I have installed 1DIN DVD/MP3/DivX player in upper glove box of my '06 CPV35. In place of DVD NAV unit.
Have to tell ya , it's not that easy as it sounds...
Thanks everyone on the forum for sharing installation tips etc... thought I'd give something back.
Bose Sounds amazing...video didn't work though :O((
Monitor was switching to JAP map with crappy message popping up all the time...
After spending a night in the garage and getting sore back I finally found the solution, some of you might be interested in.
The Fix is for Series II V35 DVD NAV unit.
Model Number: CCU-3403M
Part Name: CONT ASSY-NAVI
32pin harness:
Pin-4 (Blue/Black) Cut or better wire to a switch as I did.
Pin-5 (Pink/Red) Connect to Ground.
https://www.sau.com.au/forums/topic/406198-dvd-nav-fix/
This is not correct. When i did mine pin 8 is the speed sensor which needs to be put to a switch. But i cant find the park brake which needs to be cut in the wiring diagram. I found this by probing all the wires (use LED test light) while putting the park brake on and off. From memory its pretty close to the speed sensor wire. When you find it, just ground it.
pin 9 is illumination.....
https://www.sau.com.au/forums/topic/406198-dvd-nav-fix/#findComment-6472949
Series 1 is the white plug,
Pin 7 the purple with the white dot is the handbrake which gets cut and earthed
Pin 8 is the speed sensor which just needs to be cut. I would only put a switch there if you want to keep the screen functions working
The easiest solution would be to get it done programmatic-ally
https://www.sau.com.au/forums/topic/406198-dvd-nav-fix/#findComment-6473335
  • 3 months later...
So If the speed sensor wire is cut the screen functions would not work?
https://www.sau.com.au/forums/topic/406198-dvd-nav-fix/#findComment-6618650
I believe only in terms of mileage, maintenance schedules, and anything else that needs to measure distance travelled. Otherwise, all other functions not related to distances/speed will continue to work.
https://www.sau.com.au/forums/topic/406198-dvd-nav-fix/#findComment-6619483
  • 1 year later...
Arh SWEET so the module is under the passenger glove box area?? :yes: I was going to just splice/ground the park brake wire actually at the park brake,
but if its easier to do from the passenger module thingy even better, as I was going to do the speed sense wire also if I could find it! So that wire is
a BLUE/BLACK STRIPE RIGHT, How would one test you have the speed sense wire?
Excuse my ignorance here, im not a wiring techy at all. So by cutting the speed sense wire you can always watch video/screen function whilst on the move? A switch which some are putting in is for turning the screen off whilst driving right?
:unsure: Isnt the reason for cutting it in the first place is to use the screen on the move? Bascially just wondering why a switch?
https://www.sau.com.au/forums/topic/406198-dvd-nav-fix/#findComment-7190820
The switch is to cut the speed sensor otherwise the screen will be blocked as soon as you start driving.
The switch is there so you can still have the use of the trip computer when not using the screen.
The easy fix is just get it converted to English with the video block removed in the program.
https://www.sau.com.au/forums/topic/406198-dvd-nav-fix/#findComment-7192430
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
