Ok dudes i know i have some sort of issue with the car missing at around 4-5000rpm, which after much messin around we figure its gong to be coil packs.
We ran my car up on the dyno at my mates wshop on the weekend and ony made 134rwhp this was just over 4000 rpm
the car is r33 4door
rb25det
iridiums at 0.8
knn filter
full 3" although cat isn't hi-flowed
bleed valve standard boost ( we changed the boost in increments from 7-10psi and onlly made 2-7 hp difference
this was extremely concerning as it only put out about as much as my 900kg datto which is still pathetic.
any one else seen these types of figures.
I know there is nothing wrong with the dyno as it is the one from the recent summernats hp heroes the one that ran 1470rwhp on it, apparently most accurate in oz. i will have to tune next week but i wouldnt think that coil packs would make that much difference would they we should expect arount 200-210rwhp
comments thoughts
https://www.sau.com.au/forums/topic/40620-concerned-about-dyno-hp/
yeh i know would coil packs rob me of that much power, the air fuel ratio was cool, the curve looked ok then bang straight back down at around 4000-5000, which is where my misfiring is, hmmmmmm, i have found that it only seems to happen under heavy load, ieif i run the accelerator easing it on lightly all the way to redline, it seems to pull the right way, but if just plant my foot nothin after the 4ish you just get the missing,
sounds like car has similar mods as mine not to sure if yours is full 3" is turbs back, butwe did notice that the standard cooler is crap as we were spraying water on it and was just drying so quickly, fmic would be handy, even yours to mine 134 to 170 is a big diff!!
we could have taken it higher but it wasnt making any power past 4000rpm
That power at those particular revs sounds about right. But you should continue to make power til about 6400, or even more with your mods eg exhaust. Peak power arrives t 6400 on a standard car. hopefully its just the coil packs.
I would think if a coil pack works ok at light load, it should also work ok at full load. Not 100% on this, but you could prolly use an Insulation Resistance tester (megga) on the 1000v scale to test it (know any sparkies?). The primary winding should have continuity from one end to the other and should not be shorted to earth. I think the secondary should also have continuity from the plug top to earth on the coil pack. Please correct me if i'm way off the mark!
rb25 you would think that yours and mine should be making more power, they are around 180-190 standard from factory?
there is wear and tear but we had an older supra on there similar mods 4 years older no rebuild more kms and put out 200rwhp and they come out with 187kw factory same as skyzers i think?
similiar problem to my tuning at CRD. Mine's FMIC, unichip, full exhaust, EBC
made 163rwkw with a stuffed coil pack, replaced it and made 181rwkw on 7psi.
Jim @CRD suggested gapping the plugs from 0.8 to 0.75 if wanted to go on higher boost as the spark was breaking down with more than 7psi. Gapped it and had a test run on .8(11psi) and .9(13psi)bar, sweet.....
I had this problem on my car....the engine was misfiring and spark was breaking down at high RPM (4000 or above). Had the workshop check it out and found that 2 of my coil packs were on the way out. I bought 2 second hand replacements from the for sale section on SAU replaced the old ones and now everything is sweet. In the meantime while running with the faulty coils the workshop regapped the corresponding spark plugs closer in order to try and reduce the misfiring. As more load is put on the coils, the spark breaks down more and arcs out causing the misfire. Check your plugs as well because there could be a lot of deposit on them which may be fouling them as well.
