im bored and when im bored my brain starts wandering, technically you can run consult (ecu talk) on a windows ce powered in dash dvd/gps.
now ive just found a head unit from our good friends in china that has in built obd11, jealous much!!!? how much effort are we tlking to get this to recognize consult. heres the vid.
http://www.youtube.com/watch?v=fM3-o2QiSqQ&feature=player_embedded
Edited by Plattsy
https://www.sau.com.au/forums/topic/406216-consult-on-in-dash-dvd/
Depending on how easy it is to hack the interface ( easy most of the time) something like this would work ( windows is piss easy to hack if rhe hardware supports it )
http://www.ecutalk.com/interface.aspx
some one should give it a go!
Its not a big deal If you can get into the OS interface and hardware supports it already ??
Most of those china radios can be hacked easy to pop in your own graphics etc if you have time and it has the port or bluetooth to get into it most do
Since its just windows CE in most cases not Linux or propietarty software
Ipads can do it bluetooth and have a HD touch screen ? incar pc As well ? and ipads are way better lol you can surf porn on the road lol Not while driving of course lol
, that pop out format is old tech and blocks a/c controls and vents on a lot of cars ?? Farking hate it unless you car has no orther option
Its just not that cool to bother but feel free to go for it for sure ? always good to see interest
yea im not a of ipads 500 bucks min for something that does the same as an iphone. meh. fold out or double din either is fine, the video was really just for the program.....
Yeah on the cheap its cool but by the time you add the cost of cables etc your racking up a fair whack of $$
I know the double din china radio I have in my box in the shed could do it running CE 4 updating to the new version would open up a lot more options
not sure what chris thinks he could do it for cost wise ? but if the radio is cheap as hell it might be worth it
that does look really cool, and having just had the laptop out using ECUtalk, it got me thinking, if all you want to do is use it to run an OBD interface - you can get basic netbooks for like $99 on ebay brand new, just run one of those in the car using the obd-usb cable....would also be able to have datascan, calumsult, conzult, repair manual etc right there on the netbook as well....much cheaper and neater than buying 14 different gauges.
    • me too wasnt real happy and cost me a penny or 2 to replace
    • But there's the archetype for the name plate! Here's my view on that stupid TÜV ruleset. Buy a brand name aftermarket piece of equipment. In this case, the Mines front pipe we're talking about. Get it TÜV certified on the car. Damage the underside of it, say on a speed bump. Cut out the damaged section, replace with fresh metal. (For the sake of the argument only), continue doing that to the whole pipe until it is all gone, replaced with new metal. Is this grandfather's axe still the same front pipe? The design hasn't changed (much). The pipe walls are in the same places. The flanges are in the same places. It is functionally identical. How does this differ from a pipe that is ever so slightly different in fabrication (ie the number of welds in it, a few mm here and there in terms of where the pipes run, are joined, etc)? Anyone with 0.5% of a brain can see that there is absolutely no way that the performance (power, environmental aspects, noise, etc etc) of it can be any different than the genuine Mines pipe. Maybe even Mines made 2 versions of this design, with the same differences. How would anyone (say a TÜV inspector) ever be able to differentiate between them? And yet, they are so bloody anally retentive about this stuff. Mad. How upset would they be if you had the wrong spring washers on the flanges?
    • Sakura (cherry blossom) tree at the end of a path going through Kabutoyama Park in Nishinomiya, Japan. Taken with Sharp Aquos R8
    • After a fairly extensive search using Japanese terms and checking Minkara etc, I couldn't find anything even close to your front pipe in the photos. I'm no expert but the two pipes merge really close to the flange connected to the catalytic converter which is rather unique from what I've seen, which makes me think it's more than likely a custom front pipe. The welds and 'more pipe sections than usual for a brand name pipe' makes it seem like a custom one.  Here's some photos of an old Mine's front pipe. You can see that it's just 4 pipe sections as opposed to 6, and arguably looks more like a 'production' front pipe:
    • Wtb r33 low side s2 ac line
