Ok, so we all know that it is always better to buy a car with a full service history and logbooks to authenticate the kms (along with a mechanical and visual inspection of the car), but how much of a difference does it make to the resale value of a relatively rare car such an R34 GTR v spec II? I’m seeing more and more of them around these days with no logbooks or paperwork that are surprisingly (somewhat) clean, and I’m also seeing some around which look old and worn but with logbooks, that have obviously had the k's wound way back. So how much of a difference do you think it makes? Would you buy a car that had a mechanics ok and looked clean to you if it didn’t have any paperwork?? Also, would you go for a good but aged car with a full genuine service history and all accompanying paperwork (lets say it had done ~100,000 kms), or one which looked and felt quite a bit newer with nothing to substantiate the k's (lets say this one's apparently done only 55,000 kms)?
https://www.sau.com.au/forums/topic/406227-r34-gtr-v-spec-ii-with-no-logbooks/
End of the day all you can really do, is get a very thorough inspection by someone that specialises in GTR's.
Sort out the good from the not so good. The 2002's are over 10 years old now...
But I'd rather choose a car in great condition with no log books, then a tired looking one with log books and odo wound back.
Forgot to mention, with the odo wound back, I'd go the clean one since the books sound like they were off eBay.
Forrest Gump's mother said, "You just do the best you can with what you've got..."
This means that regardless of whether you Michael are the car's 2nd or 3rd owner since new; if you create a portfolio of all work done on your VS2 & a new log book, the time line starts now!
Any prospective buyer will see if you are an enthusiast or not. Your records will be backed up by the condition of your vehicle. And by doing this, you will be doing a wonderful job to minimise depreciation.
Furthermore, that prospective buyer will go to the next step of protecting his interests by asking you for a compression test, a hoist inspection, a discussion with your service technician and your tuner. If I were you, I would have no hesitation to welcome this level of scrutiny.
The value of your nice VS2 can be protected! :)
Regards.
Edit*
Im just noticing that you're the buyer eh?
Well reverse the roles above > bargain damn hard. If there's any doubt though, walk away!!!!!!!!
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
