Ok, so we all know that it is always better to buy a car with a full service history and logbooks to authenticate the kms (along with a mechanical and visual inspection of the car), but how much of a difference does it make to the resale value of a relatively rare car such an R34 GTR v spec II? I’m seeing more and more of them around these days with no logbooks or paperwork that are surprisingly (somewhat) clean, and I’m also seeing some around which look old and worn but with logbooks, that have obviously had the k's wound way back. So how much of a difference do you think it makes? Would you buy a car that had a mechanics ok and looked clean to you if it didn’t have any paperwork?? Also, would you go for a good but aged car with a full genuine service history and all accompanying paperwork (lets say it had done ~100,000 kms), or one which looked and felt quite a bit newer with nothing to substantiate the k's (lets say this one's apparently done only 55,000 kms)?
https://www.sau.com.au/forums/topic/406227-r34-gtr-v-spec-ii-with-no-logbooks/
End of the day all you can really do, is get a very thorough inspection by someone that specialises in GTR's.
Sort out the good from the not so good. The 2002's are over 10 years old now...
But I'd rather choose a car in great condition with no log books, then a tired looking one with log books and odo wound back.
Forgot to mention, with the odo wound back, I'd go the clean one since the books sound like they were off eBay.
Forrest Gump's mother said, "You just do the best you can with what you've got..."
This means that regardless of whether you Michael are the car's 2nd or 3rd owner since new; if you create a portfolio of all work done on your VS2 & a new log book, the time line starts now!
Any prospective buyer will see if you are an enthusiast or not. Your records will be backed up by the condition of your vehicle. And by doing this, you will be doing a wonderful job to minimise depreciation.
Furthermore, that prospective buyer will go to the next step of protecting his interests by asking you for a compression test, a hoist inspection, a discussion with your service technician and your tuner. If I were you, I would have no hesitation to welcome this level of scrutiny.
The value of your nice VS2 can be protected! :)
Regards.
Edit*
Im just noticing that you're the buyer eh?
Well reverse the roles above > bargain damn hard. If there's any doubt though, walk away!!!!!!!!
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
