In today days the process for chossing a Reputable Auto Insurance Company has become very complicated. How do you know what companies are reputable and which are just out to take your money and provide little in return? Before you shop, the first question to ask yourself is what is it you want from your auto insurance company. Mainly, you want them to:
• Be fair – handle your claims in a fair and timely fashion
• Have a strong financial outlook
• Have few complaints filed against them
• Be rated highly by private rating services
• Be honest with you – tell you what coverages you need given your circumstances and how much it will cost
• Be responsive to your questions – have someone available to answer your coverage and claim questions
• Have a history of good service
There’re so many categories of auto insurance coverage. What coverage do you need most? What can you do without? Picking up the best coverage options takes some time and efforts.
1. Go to the website of your state’s department of insurance. Therefore you’ll have a better understanding of your state’s auto insurance coverage requirements.
2. Check and review your driving record. Minimum coverage is not enough for risky drivers.
3. In addition to your driving record, you also need to consider other factors when deciding how much coverage you need.
4. Perhaps the most important step for finding the best coverage is to obtain the best auto insurance rates for your needs.
5. Extra Bonus.
Edited by kreitosune
1) I periodically talk to two of my friendly panelbeaters
2) An insurance company is hard to trust when one staff member at LSV refers to a fellow worker as a dope
3) It's difficult to stay loyal to only one insurance company when it ups the premium the following year and you find that their opposition is cheaper > back & forth: back & forth
4) With regard to your reference of honesty, it can be hard to tell if your insurance rep is honest when you can't see his face, and his fellow worker tells you something different.
5) If you've had an indiscretion, the company tries to get that money back the following year - big time - not just gradually!
I treat companies as being guilty until proven innocent. That's how they've treated me.
Too right Terry.
What other industry has moved to such widespead use of private detectives for claim interviews.
Hardly a show of confidence/competence in their own staff.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
