As some of yous already knew that we are developing electric turbochargers. (lol don't laugh)
The prototype produces 3.3 psi of boost with 0RPMs of lag on a Rb25det engine with turbocharger disconnected.
How ever the motor that I'm using draws a large amount of current. it is hooked to an spare $500 Optima 12V battery that keeps it activated on 100% throttle for 15mints (obviously a normal person would not flog their car on full throttle for 15 mints straight on road).
The motor uses 12V DC, 120amps, and up to a maximum of 2400 watts.
If I am going to hook it up to the car battery or run the 2nd battery in parallel, is there a way that I can satisfy motor's draw current without affecting car's electrical instruments?
Ie. Capacitors or some thing in similar, or couple of capacitors, or more batteries in parallels connections, can the factory alternator charge all batteries in the parallel circuit through normal driving? Please post up your ideas. Thanks.
https://www.sau.com.au/forums/topic/406245-solutions-for-high-current-draw/
Yes lol
Ok the factory alternator is 80amps max and is fused at that level even high km still test close to 80 from the ones I've checked
Upgrade charge wiire to 4 Ga
Ground the alternator frame / bracket bolt 4ga
which optimia red/ yellow/ blue ?
Yellow is best choice
You can run a pair in partallel if purchased same time , same specs and test internal Resitance is close as possible
Without a charging diode breakout , optima arent the most powerful around but still a great battery
its late now but let me layout some ideas for you and crunch some numbers
its very doable without a major drama but i can get close to exact expectations
Options
Big main battery
Twin smaller but higher load batteries
Main battery with batcap
Isolated twin batteries like 4x4 uses or huge stereos
Li ion battery
High output alternator $$$$
or a better electric motor spec
Happy to help ya
Well
Your motor has the wrong specs For 100% efficient which its not ?
If it runs 2400w max @12v that = 200amps
At 12v and 120amps max = 1440w max
Could it be a 12v/24v motor by chance ?
One of the ratings is wrong
What duty cycle do you think you would run max current draw for a min or two? most electric motors have a max duty cycle in specs ?? Your going to have to cool it somehow or it wont survive long??
Forget the physics law name but you cant produce enough power to be 100% efficient to run another device.... your battery operated motor will consume more power from the petrol motor to get the current to run the electric motor so the gain is minimal kw unless you use the electric motor that swaps to normal turbo at 3000rpm ?
To have no lag and useable boost
Or NA car looking for a cheap min mod for extra power ?
another way is use a system like kers on F1 car that stores wasted energy ? You could make one off the driveshaft using alternator or even generator and use ac or dc motor ??
that runs independent of the cars electical system
diode isolated but could be backed up by car battery in the case of no waste energy stored like on first start it wouldnt have lots of available current ?
But without more info i could only get you into a reliable solution to run 120amps even on a 80amp alternator short term
Figure 60amps to run the car on rainy cold night ?
Or hot rainy night ? with minimal buffer of course LED lights etc all help
I pull 7000watts max @12v but its for 30seconds in car audio , i use one smallish but extremely powerful battery and some trickery lol To provide that kinda power to the boot
On 80 amp alternator
And 100,000watt car audio systems exist but they operate in 16v and 4 or more alternators and a boot load of batteries Or high output mobile welding alternators 300amps plus
Anything is possible depends on your goal and specs and of course $$$$
I've Listed the wrong motor. lol.
By specification on user manual it is:
-Max. Current: 130A
-Max. Voltage: 12V
-Max. Power: 1700W
It has a 12V cooling fan and heat shield attached to it.
This electric turbo won't be running at full capacity all times, Its configured to run 100% only when throttle is at 100%, or the compressor starts to surge. In a manual car assume I'm flogging it, the time cycle between each full throttle runs are less then 10 secs before I have to release throttle and change gears. The motor is powered down when throttle is released.
Do you think a capacitor is suitable for some thing in that setup? Providing sudden discharge of 10 secs and revive it self when motor stops drawing current.
Any diagrams that you post up and show the best setup in your mind? in both bugget and not.
Cheers.
A capacitior may not be suitable as they dont discharge a constant current. After the first 1/5 of the time it takes to fully discharge the output current will only be about 30% of what it was intially. So to have a capactior that will discharge a current that high for around 10 seconds will have to be massive or have a lot of capacitors that may not be practical.
Its currently a Optima Yellow top D31A.
Really that model is a bit large for a skyline case wise ? I take it the case is light grey not dark grey?
What application is that electric motor from ? That much current sounds like it would be slow to spool up as well? Scooter or golfcart motor?
How many rpm and hp does it produce ? Sounds like a lot of hp not a lot of rpm ? in my head I would think its not the right motor for the application and overkill industrial size
A turbo spins fast and even a dremel motor wouldnt spin that fast about half the max turbo speed ?
Does the motor spin on power always ? or disengage at xboost or rpm ? like a a/c clutch setup?
I would doubt the motor use's max current draw once running on a turbine load ? have you tested it with a amp clampmeter underload? free spinning it prob uses a quarter of the current ?
Your setup would work except on short drives or bad weather days where alternator power wouldnt recharge the battery enough it would short charge often and fail in half the time of normal
A few other little glitches
the upgrades would include all main wiring to starter and charging curcuits to fusebox and of course the electric motor is borderline at 4ga wire it could overheat and catch fire 150amps max on the best 4ga wire in normal heat 23c ?
underbonnet on a hot day you could be pushing beyond the limit on the wire even at 130amps , depends how long the run is and if the wire is in cool area or next to a smoking hot turbo ?
Your going to need a resetable breaker , 20 bucks a fuse works but that size fuse gets expensive if it triggers a dozen times during testing or on roadside a button push beats trying to find AGL or mini AGL fuses in whoop whoop
Does the motor use a trigger to turn on or is just on or off all the time ? a fused relay for that
A capacitor of 2 farad (2000watt) would buffer the start but it puts a load on the alternator as well recharge making matters worse not recommended
in electric motors the cap is for a start current jump is all , in car audio a cap recharges the coil and transistors during hi current transients in the music . A lot different application then yours
If any cap was used a smaller one depending on a lot of factors / specs in motor itself ? Some have caps built in ??? the motor has to be electronically isolated so the electronic noise doesnt enter the factory ecu , knock sensors, and car radio it could wreak havoc if its noisy electronic ripple? Not a big deal to solve in most cases
If you dont want this public you can pm me nondisclosure agreement to protect your interest and i could see exactly what your trying to do ? have extensive fab and engineering skills
I see your idea kinda a no lag device ? but I ponder your exact setup might be going down a path of using off the shelf motor that doesnt suite
The idea except on a lab bench ?
Edited by Carbon 34
Agree to above , unless a small cap is needed to jump start the spin of a high torque motor , most of those have built in caps already for that reason
But it loads the alternator up making matters worse
Edited by Carbon 34
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
