R33 Gtst. Hks Gtrs/power Fc/bilstein Shocks -$9500
PRICE DROP - Hks gtrs turbo, power fc, fresh tune. $9500 - Urgent sale.
9500 Ono - swaps for Wrx my98-2000
Have found a car - urgent sale
http://carsales.mobi/cars/details/?R=13036985
Pics can be found here-posting on mobile, can't post pics?
Standard rb25 s2 engine
Hks gtrs turbo
Apexi power fc - fresh safe tune - around 270kw
Bilstein adj. suspension
New brake pads
Split fire coil packs
Aluminum radiator
Silicon intake
Silicon radiator hoses
Sard injectors
Upgraded fuel pump
Hybrid front mount intercooler
Turbotec manual boost controller - not installed
Greddy turbo timer - not installed
Viper alarm
Hicas lock bar - not installed
Heavy duty clutch
3" turbo back exhaust - no mufflers. Super loud - clean note.
Has had timing belt/seals/bearings replaced less than 1000 km ago. Runs like a dream.
Freshly re sprayed in the original silver - this week.
$9500 Ono wanting a quick sale . So make an offer .
  • 1 month later...
  • 3 weeks later...
 Share
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
