I cant do around an outside corner,
I just get a heap of wrinkles.
So half my wing looks good, and the other half is turdworthy.
The wing, front bar, and rear bar have these annoying shapes.
Can anyone do it?
Can you recommend anyone?
Or even better, teach me how.
$ Im not asking for any freebies.$
https://www.sau.com.au/forums/topic/406252-anyone-any-good-at-wrapping-vinyl/
I've done two cars. The first was an R31, really easy because of the squareness. The second was a wide body 180, That was a nightmare. Took so long and half was cheap vinyl. If you're going to do complexed curves, get the good stuff and not metalic or otherwise you will need release cuts (you will only notice these when you're close, I put them on edges).
I bought my vinyl from Sydney, forgot what they were called but the guy had done a whole heap of cars (Domino's, Jack Daniels, etc). He was really enthusiastic and helpful.
They said a bonnet wrapped in cf pattern, 1500x1400, didnt know what brand, not 3m, $600.
Its pretty flat so i can do it easy now ive had practice, for about $25
So its a no brainer man, ill just persist with the difficult bits, and finish it myself.
The wing is done, 3rd time around got it good enough. and the rest are easier shapes to cover.
Im doing the bonnet, front bar, skirts, pods, wing, and the rear bar last, ill see how it looks maybe leave the rear.
The rear bar and skirts are the only bits with good paint so they are just to complete the look.
It should be done by friday, ill bring it out.
If i can do it.
It doesent work so good in the cold, the bonnet got 90% done then it got cold and ripped.
So do it again. Oh well the wing took 3 goes.
I can bring everything inside i guess, if i can keep bubs away from it.
See how it goes.
ill come out anyway with whats done.
Then you can see some mistakes too.
Doesent matter cos its just my s-box.
You should still consider it.
Its difficult, not impossible. And would be easier with more expensive stuff im sure.
The prep is 10% of a paint prep. Which is heaps of time saved.
Getting it done by a pro would still cost much less than a paintjob.
Anyway, just the bonnet to go now, ill leave the rear bar till later, and reassemble.
Ill post pics of the dodgy bits too so you can see what the deal is.
The rest looks realy good.
But I think 'Dammit' didn't realy express your feelings when you stepped back and had a look.
Thanks, no dammit is for the public, haha.
Heres the bits that worked ok (pics).
Is the square in the middle on purpose?
Yes thats a patch where i ripped it and wrinkled it and generally fked it up.
Its a dodgey patch cos im going to have another go anyway.
You can see a couple of small patches on the front bar, thats because of the extreme corner.
Homemade decal covers missing paint.
I think ill do the rear bar too.
    • Hi everyone, Apologies in advance if this feels like a topic covered multiple times. I'm only asking because some of the old topics I found are missing images now. I'm in the process of getting a manual boost controller (BC). Nothing fancy, just getting a manual one for now as I don't plan to go crazy with it and would not go over 10 PSI. My car is not jacked up on boost steroids to do crazy numbers. I want to understand the OEM setup of the boost solenoid and vacuum lines on the R34 GTT so I know what needs to be changed when I do install the BC. I sketched the current setup to the best I could see and it's on the diagram attached. If the boost controller 'Wastegate Arrow' goes from nipple 1 to 2. My understanding is that the red vacuum line's "F" connector-end should be connected to BC nipple #2? Nipple #1 is meant to have the "pressure source" so what vacuum line would that be? Is it the green vacuum line?  From what I have read here, the OEM boost solenoid is not used at this point. So that can come out and then I can just plug the nipple that usually connects to the blue vacuum line?  So would the final setup look something like this?   Thanks in advance. I don't want to already be knee-deep into pulling out vacuum lines before understanding this. I'm a noob when it comes to boost setups so trying to learn as I go.
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
