So I've been told that Supra's drink petrol like its water.
Well I can give you the exact answer your looking for.
I get a good 425KM running on a full tank of Premium 98 before the empty light comes on. I believe it could do at least 450KM before I start running on fumes, but I tend not to risk it, although I do plan to run completely dry until my 34 becomes dehydrated to the point the engine shuts off just to see the MAXIMUM it can do on a full tank.
Gotta get myself a Jerry can first.
But to answer your question, 425KM on full tank of 98. Auto R34 25GT with RB25DE, no mods. Costs me about $140 a week though to run, since it's my daily and I drive it to city and back most days.
you should have roughly 10L of fuel left in the tank once the light comes on. in the case of my commodore though, i drove from gympie to noosa (just over 60kms) with the light on and then filled up to find i still had about 10L left in the tank. in the pulsar though, the light comes on fully with about 8L to go, but starts coming on then going off at about 11L to go.
back on topic though, if you want something RWD with better fuel economy than a skyline or supra, then get a silvia. the SR20 is a more fuel effecient motor.
Don't know if your being sarcastic or not :unsure:
But if legit question, you don't have a fuel warning light on your cluster?
not being sarcastic, looking back now the post does sound very dumb.
I actually dont have one, looked real hard at the dash too. I managed to run my tank almost empty to see if anything lights up.
I've heard of other skylines being like this, but im not concerned with it so never bothered looking it up.
I was under the idea that the na models, being the cheaper ones, nissan might have skipped over that.
mines an auto n/a and i get around 400-450kms out of a tank of 95 mixed highway and town, good weeks i can push 500 before running on fumes, mostly highway .... but if you put your foot down it can easily only do 300-350 flogged around town ....
My 34 is NA. maybe a pre-R34 thing? or perhaps your LED blew out.
they certainly have one. all modern cars do. there would probably be some sort of regulation that requires it.
it may be that the bulb is blown or the sensor in the tank is faulty.
i'm trying to remember where it is in the r33. i have a feeling it may be in the same cirlce as the fuel gauge, rather than being a seperate light like the handbrake light, etc. but if someone has a cluster handy, they could just remove the bulbs at the back and shine a torch through and you would see what each bulb does when you look at it from the front
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
