hey everyone,
wierd problem, my number plate lights have stopped working, along with 1 of the reverse lights .... has anyone incured this problem before?
I'm currently trying to find an english conversion/version of the interior fuse box to see if its a fuse problem, however a 'fuse' problem would tell me that "both" reverse lights shouldnt be working not just 1 or the other ..
did a search on here, and doesnt seem to be anyone posting this issue before, but i'm hoping someone might hvae some info on how to help with it...
cheers guys!!
reverse lights are powered thru a single 10A fuse (#71) in the fuse box behind the battery
number plate lights are powered thru a single 10A fuse (#75) in the same fuse box, which also powers your tail lights and parkers.
if either fuse was blown you would have many more lights not woking.
edit - it wont be a fuse problem but heres a quick tip. number plate bulb is a T10. you could swap it with your boot interior bulb to check if its a fuse or possibly a socket problem
reverse bulbs - just swap them around to check if its a fuse or even a poor socket. theyre an oddball T15 i think
Edited by Deep Dish V35
its a defect to have any form of light missing/broken its 1 point and $100 if im correct and it also may lead to other deffects as such
Think that you've got two different problems mate.
Try replacing the reverse light bulb and not worrying about the number plate. If people can't see it at night, that's a good thing... right?
http://www.police.ql...8/Ch_08_PT2.htm press (CTRL + F type in light)
Interesting...Got pulled for it in NSW and just claimed that I didn't realise - which I didn't (long trip from Brisbane to Sydney and was tired).
Copper allowed me to drive to a servo and pick one up. Just let me off like that, hence why I didn't think it was defectable.
Also, this was when I was in my S13 and looked like a h00n!
well got some bulbs from mate @ http://www.86forums.com.au , these LED fancy thingos, just need to get some time to try slot them in ...
and with the reverse light, my rachet broke, so i cant get the damn tail light out :( was one of those weekends
errr , im just worried about getting the lights working over the # plate :P
currently 1 reverse light still lights up a bit, sux where I live its a dark corridor to reverse down, so i've gotta feather the brake to help me see if any kids decide on doing a bolt
    • She swallowed the spider to catch the fly.
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
