Cracked Rim!
So I couldn't work out why my tyre kept on going flat couldnt find a hole anywhere so I chucked it in the pool and found that the rim was cracked on the inside,,,,,,
So dose anyone know where I can get it welded up if it's possible ,,,,,,,,,...
I'm in Sydney.....
Cheers
I would try Magman too.
The guy at Minchinbury tried to TIG my LMGT4 but it cracked again on a country road no less > Had to get it fixed again at One Stop Unanderra
Yeah it's a rota wheel it's about 50mm long...... How much did it cost ruffly if it's 100-150 and If there is a chance that it could crack again it might be worth just getting a new rim from rota......
Thanks for the info too.....
Yes, that's about the cost.
Before they weld, they usually spin the wheel and chalk the rim if it's "out of round" > call you if it's not repairable.
Prior to welding, a "V" groove may be cut on both sides.
 Share
