Damn, i thought the newer generation of coolants were environmentally friendly(er) n putting them down the drain wasnt a problem.
Not so the case?
I asked the local Natrad bloke what he does with his waste, he said he treats it (to even out the PH I think) and then dumps it down the drain.
There are many neutral pH substances that should never be dumped in a drain.
The treatments he uses might include (amongst other things) surfactants as well as acid/alkali chemicals I think
just tip it on your weeds....
don't pour it down the drain and do not tip it on your weed...
I just chuck it on the plants...doesn't seem to do them any harm, in fact I noticed that at my parents house the weeds that my father emptied coolant on did better than the neglected adjacent weeds which didn't get a watering.
Lol seems like my "pouring down the toilet" post got deleted.
The only reason i said that is because all sewerage in the City i lived in is processed in a treatment plant before going anywhere near the ocean. The water outlet from it is cleaner than the water its being dumped into. So really its not a bad option. :)
And im pretty sure a treatment plant is well equipped to handle anything that could possibly be flushed down a toilet. They would have had it all and some.
Edited by gotRICE?
If some of you have seen what ends up in the tips, and leaches into the ground, Coolent it the least of your worries - Though im not one to add to the crap land fill.
Check with local council - i know mine has cirtain days per year were they set up a big chemical/paint/oil waste disposal at a local carpark,
They let you bring it all and dispose of it, Best thing it, due to saftey they wont let you out of the car, So pop your boot and they will grab it all out for you :)
Actaully my local council has some good services- Free woodchipping/mulching 5 times per year its great. Free mulch and dont have to take anything to the tip, Just go nuts with the chainsaw and leave it all out the front drive way- Come home to 6-7 bags full of fresh mulch.
Edited by sydking
Thats cool!, Our here in sydney goes straight out intot he ocean, Feild of mars even has the old above ground sewage tunnles from many years ago.
And wasent it maroobra beach back in the day that had the sewage pipes leading straight into the beach haha
whilte the sewerage processing systems can deal with it, doesnt mean that it easily or prefereably can. For example, the amount of processing that it takes to sort bleach via the sewerage system is huge. But of course most people do use bleach in their toilets n sinks. But, essentially, its bad for the sewerage processing system.
Im sure coolant would also fall into this category.
OK, I've just asked my neighbour Ricky, who has a 80 year old Antique car.
He (Alan) will gladly take that pre-1985 coolant off your hands :)
I can pick it up for him.
Sure man, but its a little bit of a drive to pick up for a bottle of coolant!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
