Justin's Pie Cruise! Sept 16Th Robertson Pie Shop!
Hey guys,
I haven't run one of these in a while and they always get a great turnout so who's in for an awesome drive and a nice pie or 3!
The day's pretty simple we have 2 meeting points, 1 at Casula KFC bunnings/ 1 Down at a school in albion park? (owen/CPD), Meet there at designated times and have an enjoyable SAFE day! This is an UN-OFFICIAL Cruise but we will be on public roads and representing the club so all traffic laws are to be followed! (anyone who doesn't will be reported to the authorities, Because no one wants Police showing up and ruining a Good Day)
INFO:
The cruise will be held on September 16th (Sunday)
Meet: -Casula Home depot center KFC Car park at 10 AM For 10:30 AM SHARP Departure.
- Albion Park School, The south guys will have to orginize a time to meet down there, Everyone from Casula
will arrive there roughly around 11:45 AM (1 hour cruise time to be comfortable).
What to bring: - Yourself, and friends, everyone is welcome as long as they have a good attitude!
- Full tank of fuel (we will not be stopping)
- Camera
- Money for your lunch. (there are ATM services available)
ROUTE: -Casula KFC Down onto the hume highway, Follow that all the way down to Picton road.
-From Picton Road we will be turning left on MT Keira Pass (we normally don't do this but it's more interesting
and no real side track from the cruise less highway more turns!
-From Mt Keira Pass Head down onto the princess freeway at the last set of lights we turn left, then onto the
princess highway onto Jamberoo road.
-Left into Albion park which we will meet up with the south people and then follow that road Up MAQ Pass
onto the pie shop!
WHO"S IN!
  • Replies 98
Posted Images
Should be in, will check with zee boss.
Alright then...
You can go!
You realise when you come back, you have to clean the dirty dishes, waterproof the cellar, vacuum the house, harpic the toilet and bury the cat!
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
