Justin's Pie Cruise! Sept 16Th Robertson Pie Shop!
  • Replies 98
Posted Images
Guys, This date is pending on weather, Went and did this run again last night and it was raining, it was an absolute waste of time... So if its raining we will post pone.
Really? Are you that much of a pansy you won't drive in the rain, or is it just that your car leaks/lacks a roof?
I'd only avoid Mac Pass in extremely extremely cold weather (Like we had last friday) and it's raining, this equals snow + black ice.
Oh and in a raging thunderstorm that you really shouldn't be leaving your house because of, as it'll bring branches down.
I'm not a Pussy, I'd just rather post pone it so that Everyone can enjoy each others cars, in the nice sun like we normally get when we go up there as a club, But if this recent weather reflects on what it's going to be! All lights are green!
leave time 10 A.M or is that to early for everyone?
Hey, I'll be coming as well. Can you give me a little summary of this thread? So far I've picked up: Meet at Casula KFC @ 10AM, Sunday 16th.
Meet Car Park 9:15 Am Onwards, DRIVERS BRIEFING AT 9:45 AM! 10AM SHARP DEPARTURE TO ROBERTSON PIE SHOP VIA, HUME HIGHWAY-PICTON ROAD- MT KEIRA PASS- EXPRESSWAY TO ALBION PARK SCHOOL - MAQAURIE PASS- PIE SHOP- EITHER GO HOME OR DO JAMBEROO PASS.
Bring, Fuel, Safe Driving, freinds, Camera.. Money for Pies and other foods once we arrive. Follow the White R33 (Mine) And the Purple GTR (Owen) We Will Be Leading the cruise and sticking to the speed limits at all times, make it a nice cruise with each other no need for speed, just enjoy the roads and the company.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
