Justin's Pie Cruise! Sept 16Th Robertson Pie Shop!
  • Replies 98
Posted Images
Guys, This date is pending on weather, Went and did this run again last night and it was raining, it was an absolute waste of time... So if its raining we will post pone.
Really? Are you that much of a pansy you won't drive in the rain, or is it just that your car leaks/lacks a roof?
I'd only avoid Mac Pass in extremely extremely cold weather (Like we had last friday) and it's raining, this equals snow + black ice.
Oh and in a raging thunderstorm that you really shouldn't be leaving your house because of, as it'll bring branches down.
I'm not a Pussy, I'd just rather post pone it so that Everyone can enjoy each others cars, in the nice sun like we normally get when we go up there as a club, But if this recent weather reflects on what it's going to be! All lights are green!
leave time 10 A.M or is that to early for everyone?
Hey, I'll be coming as well. Can you give me a little summary of this thread? So far I've picked up: Meet at Casula KFC @ 10AM, Sunday 16th.
Meet Car Park 9:15 Am Onwards, DRIVERS BRIEFING AT 9:45 AM! 10AM SHARP DEPARTURE TO ROBERTSON PIE SHOP VIA, HUME HIGHWAY-PICTON ROAD- MT KEIRA PASS- EXPRESSWAY TO ALBION PARK SCHOOL - MAQAURIE PASS- PIE SHOP- EITHER GO HOME OR DO JAMBEROO PASS.
Bring, Fuel, Safe Driving, freinds, Camera.. Money for Pies and other foods once we arrive. Follow the White R33 (Mine) And the Purple GTR (Owen) We Will Be Leading the cruise and sticking to the speed limits at all times, make it a nice cruise with each other no need for speed, just enjoy the roads and the company.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
