Hey guys,
So im looking to do a front end conversion to my R34, GTR bonnet and bumper etc just for cosmetics ;)
Anyone know of somewhere decent who stocks these in Aus, not really fussed about the colour i can respray.
Am i best to go fibreglass or spend the extra????
https://www.sau.com.au/forums/topic/406383-gtr-cosmetic-conversion/
If you buy a Fibreglass kit you'll find one easily and not need to do the whole conversion ie. bonnet, guards, lights etc. It would be substantially cheaper and a whole lot less work to do this.
Keep in mind if you source a genuine GTR front bar and want it to fit CORRECTLY, it will also require GTR headlights, guards and bonnet. If you factor this is in with the cost of labour to fit, plus respray, it will be excessive and substantial. If you can do the work all yourself you could save some coin, but I'm presuming you'd need the work done too.
That's just my 2 cents worth however. If you want to do it, then do it! Numerous threads on this bud so have a search.
Also should have mentioned, if you do buy a GTR front bar (genuine) and fit it without the proper hood etc it will create a slight over hang and gap between the headlights.
Edit: just read through your post again and realized you were aware about the bonnet etc!
Edited by gtsttrk
TLDR go fiberglass its easier
Just to clear up, you don't need to change your headlights, they are the exact same. I've done this conversion. If you use all genuine parts, you will need, gtr front bumper, fenders, bonnet, bonnet catch, bonnet hinges. (the last two are diffrent between gtt and gtr) Where the gaurds mount in the engine bay you'll need to space up approx 20mm with spacers. Also using factory gear, you won't have issues fitting and lining parts up, so would be an easily acheivable diy job. Again with spraying, depends on your own personal experience/competency. If you go to the extent of whole car you'll be looking at alota dollars to get genuine rear quarters bumper skirts, fuel flap taillights. I did mine all out of fibreglass, only diffrence is mine slightly wider due to the type of rear quarters I used. Fitting these was very time consuming, but of little cost doing myself. I imagine paying to have done will add up quickly. Hope this helps and gives you an idea of whats needed/involved
Hey matey I have also done this conversion with all genuine parts and I don't recommend it lol it was very costly... Um the only thing that doesn't bolt straight on is the guards U have to get spacers made up.... The headlights bolt on U just need the gtr head light brackets
not sure how much you're looking at with genuine parts.
East Bear might be an option. Pretty expensive but might not work out as expensive as genuine (but will probably come close).
keep in mind, this stuff comes from japan.
theres a 2 piece kit so you can use the oem bonnet
http://www.rhdjapan.com/east-bear-2-piece-front-set-stock-bonnet-type-i-nissan-r34-zenki-67858
or theres 4 piece kits
http://www.rhdjapan.com/east-bear-4-piece-new-type-gts-r-front-set-frp-bonnet-zenki-r34-53796
http://www.rhdjapan.com/east-bear-4-piece-gts-r-front-aero-kit-r34-skyline-61210
  • 3 weeks later...
I don't think anyone mentioned that Fibre Glass will crack. I'd go a little extra and get genuine or non-fibreglass parts cause if you scrape or hit something like the gutter, it'l crack and more money gone. That's the only downside.
+1
I've been here. Not sure of any local companies though that make non fibreglass, unless of course you're talking OEM.
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
    • I used to love going to Amaroo to watch the HQ series go for broke (eventually stopped due to lack of spare parts) and also the Porsche series.  It was so cool to back your car up to nearly the edge of the viewing barrier and party with your friends, having a bbq and alcoholic/non drinks. It was such a family/mates atmosphere
