Guest RedLineGTR Posted May 10, 2004 Share Posted May 10, 2004 Okay, I need peoples help I need a dump/front combo pipe fitted to my r33 gtst, most exhaust places say they can fit it no problem some are willing to charge me more since they aren’t sure of the time it will take etc, some exhaust shops say they have worked on r33's before lalalala and have done work for other performance shop, but I have had little things done by these (recommended places by performance workshops) and I have gone away with a product that I’m not happy with. I need someone around this side of town (chadstone, dandenong etc) that: - Knows R33 Skylines or skylines in general. - Has fitted a dump/front pipe combo or something custom before. - Has half decent prices (as long as the job gets done well). - Not located on the otherside of town. Any recommendations and possible names of people that have some knowledge and some good service, would be very grateful!!!!...unless someone has done it before and has the tools the get it done?? Thanks for your time. Cheers Rob Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/ Share on other sites More sharing options...
meshmesh Posted May 10, 2004 Share Posted May 10, 2004 Yes to all of the above expect for location. Ask for Paul - Glenroy Exhausts in Campbellfield Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-833875 Share on other sites More sharing options...
Guest RedLineGTR Posted May 10, 2004 Share Posted May 10, 2004 Thanks for that meshmesh, if all else fails i will have to drive quite a bit from where i live, hopefully someone will have one around my area if not then i'll pack my picnic and have a drive to Campbellfield. Thanks for your post, Cheers Rob Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-833916 Share on other sites More sharing options...
acsplit Posted May 10, 2004 Share Posted May 10, 2004 Rob are you after a split dupe pipe / wastegate pipe pff the turbo? or do you already have one. i believe the rb25 turbo has the wastegate flap in the dump pipe so you can only get a 3" flared pipe from the end of the cast section to the cat. Until now i have a friend who owns and exhaust shop and is designing custom split dump pipes with seperate wastegate pipe and the wastegate flap inside it. Hel also does turbo manifolds etc and is very good we send all our cars there and always happy customers . rob speak to me on msn if you don't understand what i just posted lol or Call Exhaust Worx 97611124 Les is the owner there. But its in Bayswater but you know all the good workshops are in the south /east / eastern suburbs cheers Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-833944 Share on other sites More sharing options...
Guest RedLineGTR Posted May 10, 2004 Share Posted May 10, 2004 Rob are you after a split dupe pipe / wastegate pipe pff the turbo? or do you already have one. I already have one, i have looked at both but found the prices to be the main difference. i believe the rb25 turbo has the wastegate flap in the dump pipe so you can only get a 3" flared pipe from the end of the cast section to the cat. I have a flared pipe so to speak, the only split ones i have seen have been in stainless steel (worries about it cracking) and the price range was abit too high, the split dump even in mild steel would have good benifits as compaired to the flared one but, found a good price for this one and the split type dump wouldnt make too much of a difference in such mild modifications atm. Until now i have a friend who owns and exhaust shop and is designing custom split dump pipes with seperate wastegate pipe and the wastegate flap inside it. Hel also does turbo manifolds etc and is very good we send all our cars there and always happy customers . Ah sweet, someone to talk to about some future projects etc and maybe get some prices. rob speak to me on msn if you don't understand what i just posted lol Nah i understand what your saying if i need anymore info i will msn you, at school atm Thanks for the reply :headspin: Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-833973 Share on other sites More sharing options...
CR34TION Posted May 10, 2004 Share Posted May 10, 2004 exhaust shop try Matt... Pushead got him to install his dump/front pipe combo. Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-834001 Share on other sites More sharing options...
THE CHIEF Posted May 10, 2004 Share Posted May 10, 2004 Pete at Ferndale exhausts in Knoxfield.. top quality and excellent prices! Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-834275 Share on other sites More sharing options...
Guest RedLineGTR Posted May 10, 2004 Share Posted May 10, 2004 exhaust shop try Matt... Pushead got him to install his dump/front pipe combo. matt dosent work their anymore..moved on somewhere...might go to DAALDER exh. in Box Hill but wasn't too confident in the conversation at hand. Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-834584 Share on other sites More sharing options...
paulr33 Posted May 10, 2004 Share Posted May 10, 2004 ice performance in cheltneham should be able to do it. tried contacting them? Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-834671 Share on other sites More sharing options...
WazR32GTSt Posted May 11, 2004 Share Posted May 11, 2004 well i can reccommentd: Blinky's Brakes and Exhaust in Dandenong (sth gippsland highway)... they did my and coco69's intercooler piping and gave me a price $300 cheaper than ice performance! trust me they are cheap and did a fantastic job. Ask for stuart and tell him Warren sent you (the guy with the blue r32 that got his intercooelr piping done) good luck! PS my dad and i fitted my front/dump by driving onto car ramps and doing it fron there. hard work but free! another option if you are good with a spanner or two... Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-835423 Share on other sites More sharing options...
riggaP Posted May 11, 2004 Share Posted May 11, 2004 Do it yourself and save $$$ Its just a coupla bolts and an oxy sensor. I watched mine be professionally installed (30 mins... if that) and was disgusted when I got the bill. Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-836541 Share on other sites More sharing options...
skylineakt Posted May 11, 2004 Share Posted May 11, 2004 I also have heard really good stuff about Blinky's at Dandenong from Coco and a few of my other friends. They don't charge you an arm and a leg and I do believe they have worked on Skylines before. Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-836823 Share on other sites More sharing options...
Guest RedLineGTR Posted May 12, 2004 Share Posted May 12, 2004 Do it yourself and save $$$ Its just a coupla bolts and an oxy sensor. I watched mine be professionally installed (30 mins... if that) and was disgusted when I got the bill. I have tried, but you need some specific sockets that are nice and thin, i had a look in a car store to see what they have, found some that would work but i would end up spending nearly the cost of the install itself. Cheers Rob Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-837852 Share on other sites More sharing options...
riggaP Posted May 12, 2004 Share Posted May 12, 2004 I have tried, but you need some specific sockets that are nice and thin, i had a look in a car store to see what they have, found some that would work but i would end up spending nearly the cost of the install itself. Cheers Rob Thats the biggest argument for doing it yourself! Next time you need to install some hardware under the hood the tools will already be there and pay for themselves! If the tools are cheaper, you save money. Even if the tools are only $1 cheaper you're still going to save money (I mean to sound like a tight arse, I'm making a point). You'll also know with 100% certainty that the job has been done properly, and working on the car is fun!!! Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-838007 Share on other sites More sharing options...
WazR32GTSt Posted May 12, 2004 Share Posted May 12, 2004 be careful though... we snapped a bolt goping into the turbo and had to drill it out - BIG pain in the ass! Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-838180 Share on other sites More sharing options...
Guest RedLineGTR Posted May 12, 2004 Share Posted May 12, 2004 Thats the biggest argument for doing it yourself! Next time you need to install some hardware under the hood the tools will already be there and pay for themselves! If the tools are cheaper, you save money. Even if the tools are only $1 cheaper you're still going to save money (I mean to sound like a tight arse, I'm making a point). You'll also know with 100% certainty that the job has been done properly, and working on the car is fun!!! the way things a going i probably will (its all your fault :jk: ) when i was doing it myself i pretty much got all the bolts off except for 1-2 bolts which i couldnt reach. You’ve inspired me !!! lolz Anyone need some dump/front pipes fitted by the way??? if i get mine on lolz Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-838296 Share on other sites More sharing options...
Guest RedLineGTR Posted May 12, 2004 Share Posted May 12, 2004 be careful though...we snapped a bolt goping into the turbo and had to drill it out - BIG pain in the ass! thanks for the heads up, heard about that happening a little while back...when i tryed it myself sprayed some WD40 just in case and pretty much most of the bolts came off fine except the ones i couldnt get too Cheers Rob Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-838303 Share on other sites More sharing options...
WazR32GTSt Posted May 13, 2004 Share Posted May 13, 2004 my issue was: tightening bolt... tightening bolt... tightening bolt... just one more turn... SNAP! followed by abusive swearing! but lucky it was the bolt that was easiest to access. also because we drove the car up onto car ramps we could get to 3 bolts from the bottom REAL easy. might be worth a try. good luck! Waz. Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-839552 Share on other sites More sharing options...
Guest RedLineGTR Posted May 13, 2004 Share Posted May 13, 2004 my issue was: tightening bolt... tightening bolt... tightening bolt... just one more turn... SNAP! followed by abusive swearing! but lucky it was the bolt that was easiest to access. also because we drove the car up onto car ramps we could get to 3 bolts from the bottom REAL easy. might be worth a try. good luck! Waz. Thanks man I really appreciate the info. Cheers Rob Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-839875 Share on other sites More sharing options...
WazR32GTSt Posted May 13, 2004 Share Posted May 13, 2004 let us know how you go... Waz. Link to comment https://www.sau.com.au/forums/topic/40639-need-an-good-priced-exhaust-shop-for-fitting-a-dumpfront-combo-pipe/#findComment-839992 Share on other sites More sharing options...
