Wtb: R34 Gtr Instrument Cluster (Or Just The Front Lens If You Have One)
Hi All,
Looking for a replacement R34 GTR instrument cluster in mint condition.
Want to pull the plastic lens off the front of it, mine has a few scratches.
Would prefer a standard vspec one, but would also consider the nismo 320km/h dash.
Cheers.
Thanks mate, have thought about wet sanding / polishing with meguiars compound and plastix.
If I dont have any luck sourcing one though, my plan is to order a new replacement via Nissan direct. I want it to be perfect.
Bump, still looking.
Also, my number is 0468 895 020 if you have one and would prefer to call.
Cheers.
Edited by iwanta34gtr
Thanks for the offer and SMS mate, but looking for a vspec one with the different tacho.
I want the front plastic and have a mate that wants the rest of it.
If things change, will get in touch with you.
Thanks mate, however would prefer a vspec one (with the different tacho).
Or a Nismo one.
Cheers though.
As above.
Cheers.
Blah. How rude of me.
Reading that again I was watching TV and wrote that in a rush, just realised it doesnt really answer your question sorry.
Yes, I believe the lens would be the same however I would have no need for the rest of it. Probably the same lens off a GT-T too.
I have a mate that wants the vspec tacho and the silver garnish, if I source it he said he would just swap the plastic lens with me.
Otherwise, if no luck then plans are in place to purchase a brand new lens from Nissan direct when time allows.
Cheers.
Yeah I saw that initial post you quoted regarding your friend, but by saying you would purchase from Nissan as a last option suggests you aren't 100% on getting the odo itself as well. Perhaps consider buying a whole cluster (providing adequate lens condition), swapping out the lens, then re selling the whole cluster regardless of gtt, nonspec etc. A bit more work but will give you more options for purchase and will most likely work out cheaper than any other option. Food for thought
Thanks mate, appreciate the advice.
A bit hesitant to purchase a non vspec dash as I may be stuck with it, they seem to be a tad harder to sell.
I think a brand new one from Nissan direct may be the way.
Cheers.
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
