Up for sale are my enkei rpf1's. Silver in colour. Perfect size for 33/34
I want new wheels and dont have the space to hoard haha.
2 are in great shape, alas 1 has reasonable gutter rash and the other has slight gutter rash.
Yes it is repairable.
No tyres included.
$1200
Sydney
Pictures up shortly
https://www.sau.com.au/forums/topic/406392-fs-enkei-rpf1/
what offset mate? and reason for sale??
In the heading chum.
18x10.5 +15. The offset you shouldve gotten addz haha.
I want something else and dont much care for hoarding. Those pictures I just took, so as you can see, they arent bent, they dont leak air. Its just time for a change
https://www.sau.com.au/forums/topic/406392-fs-enkei-rpf1/#findComment-6475961
cough hoard for track rubber cough
good luck with the sale mate
Thanks man. I might just do that, but then the gf nags, and then i tell her this is my house! Haha
I swear, all the good and cheap wheels are in nsw :(
Just work out some freight :P
https://www.sau.com.au/forums/topic/406392-fs-enkei-rpf1/#findComment-6476941
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
