Hey guys, I've been looking at getting a new car lately, as my current one can't tow a trailer (Contains all my dj stuff)
Anyways, I've been looking for something sporty and partially practical, so i've been looking at a few skylines.
http://www.gumtree.com.au/s-ad/liverpool/engine-engine-parts-transmission/skyline-r34-gti-engine-parts-etc-/1004814415
Those kind (Minus the red interiour) are really what im after, I love them in that kind of "Mid night black"
Im not a hoon of any kind, and am a very caucious driver.
One problem is though that I need something half economical, as I travel between many schools every day doing IT administration and courdination. (Works out to about 600 k's a week)
I was hoping that I would be able to get 10k's a litre out of one, but it's not seeming that way.
Also under south australian regulation, as a P plater I am not allowed to drive a turbo of any kind (Unless diesel) until I have my full licence.
So is a skyline the right car for me?
https://www.sau.com.au/forums/topic/406395-is-an-r34-the-right-car-for-me/
Harey on here has a tow ball on his GTT I believe.
I have to agree with the above though, OP. A Skyline is really the wrong car for the job, they don't have the low-down torque needed to pull a trailer effectively. RB's love to rev, they're not designed for pulling power. You also won't get anywhere near 10l/100km's with an untuned RB25DE. My old engine used to get me about 350km's to a tank. Kwaka is spot on, an AU or even an older EL/EF Falcon would be more the vehicle to suit you.
Definetly not, I'd reccommend something like a Holden ute, ford falcon, or a ford/holden wagon they are used alot for towing trailers etc...
A skyline is not designed for that and should be enjoyed not used as a work car to tow heavy equipment around.
Edited by DarkRyda
The trailer im towing is a super light bare bones 500kg (When fully loaded) A frame job, But il head your advice.
I might go to one of those government options where they auction off the ex-fleet car's. If I stick around for long enough I might get something.
One of my things is getting something a little bit luxurius/sporty.
Cheers guys!
Edited by TheMysticGoose
i tow my tinny with my SSS pulsar. it does the job fine (sits on 100kmh fine), but you know it's there. i've towed a trailer with furniture and stuff on it as well. does it fine around town too.
having said that though, depending on how much stuff you have, and how bit it is, you may fit it in the back of a commodore or falcon wagon without having to use the trailer. with the rear seats folded down you can fit in a heap of stuff. not to mention being super comfy. i have a VT wagon as my daily drive. i drive just under 65km each way to and from work every day.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
