hey guys,
I am sure this is a recurring problem for all 32 users experiencing problems with this circuitry.
I have spent a few hours looking for information on this but nothing is shedding light on the problem.
This is the forum I have found most relative but its 2006! -> http://www.skylinesa..._1#entry5275351
My old rotary headlight switch started playing (LHS turning off then Driver's side etc etc) up so I replaced it with one from the wreckers. I have noticed this one is heating up also and those little black pins will distort within a few months and I will be back at square one. It will be the same when buying a new one.
However, I did find a useful link -> http://www.danielste...ays/relays.html
From the above forum and I am using the R32 Car Manual.
I have begun creating the harness but I need tips on how to remove the old wiring? With the relays in the new circuit will it eliminate the need for those tiny springs inside the headlight switch?
I feel that part, the heating (due to resistance) and the OEM low gauge wire running all the way to the headlight switch are redundant and need to be replaced completely.
let me know what you think.
-Damien
N.B I have PM'd some of the members in the forum above.
Edited by DaShMiEsTeR
Headlight Rewiring
This is what I ended up with. I am waiting for the car battery to charge fully before I give it a try. I stupidly forgot to take a picture of it before I started wiring it in.
There is also a 30A fuse in between Battery + and the Relay "Power In" (30). Edited by DaShMiEsTeR
I have the whole setup in at the moment. I am kind of stumped with wiring the switch in. I have nothing else but the harness hooked up to the battery.
I used the 2nd configuration in the link here --> http://www.bcae1.com/swrelay.htm
I have tried a few ways to wire it in but this seems to be right. I am not sure if I should ground the switch also but I am going to try my friends HID ballast's this weekend because it could be those. I have 3 sets of bulbs so I am certain it is not those.
I will post a picture of what outcome I get. I am positive the lights will be much brighter than those running HID's on OEM wiring. The thicker gauge wiring and shortened circuit will attribute to this.
Was only about $50 all up from Super Cheap for the following:
Approx. 3-6m - 25AMP Wire ( I got varying colours for Negative and Positive and a third for the headlight switch circuit - plus bright colours were cheaper)
Approx. 3m - Any lower gauge wire because it only needs to switch the relay.
x1 Pack of Ring connectors for the battery terminals
x1 30Amp12V Relay with DUAL 87s (mine is 'Hella' brand)
x1 30Amp12V Switch
x1 30Amp 12V Fuse holder
x2 generic plastic plugs (x2 sockets (+) & (-)) for HID negative and positive for easy removal in the future.
x2 Red & Black tape for labeling and insulation
In addition to the above I have used:
-A soldering iron with rosin core
-some left over bits of heat shrink to make it neat
-Some old speaker cable with zip ties for trace line
-multi-meter to check voltage rates
-can of Contact Cleaner
I am about to call the Auto Electricians. I hooked everything back up and went to test the circuit and now my car won't even crank or switch on the Accessory lights!!!
I have checked every fuse and remounted/cleaned the grounded terminal on the car that the battery feeds to.
ANY HELP would be appreciated.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
