hey people, just wondering because its pretty fustrating. doesnt matter how much soap i put it suds up nice for first few seconds then after you start using it, it goes to water,
ive tryed maguires wash and wax, and mothers carwash (both not cheap products)
i first put hot water then use gerni to get it mixed nicely
anything im doing wrong?
https://www.sau.com.au/forums/topic/406490-carwash-soap-doesnt-sub-up-well/
ideally the best way is to first fill up your bucket with water then add the soap whist mixing it in by hand - the reason for this is that you want the soaps and suds to be kept inside the water, keeping it slippery and lubricated
so when you use your mitt/sponge to absorb it and go over your car, there is the maximum amount of slip and lube between the mitt and your paint
IMO bubbles are wasted lubricant that should be in your wash solution not on top
also pretty basic but make sure you are applying the correct amount of wash as per the size of your bucket - ie wash and wax recommends 30mL/4L so if your bucket is 8L, use 60mL if it is 12L use 90mL and so forth - i bought a plastic measuring cup from the $2 shop which allows you to use the correct amount without wasting any
One of the better car wash vids - if you wna skip straight to where he pours the soap into the bucket its @ about 5:00
<iframe width="420" height="315" src="https://www.youtube.com/embed/rqdEVtOPKAM" frameborder="0" allowfullscreen></iframe>
Edited by squareznboxez
Suds really aren't too important mate, Final inspections PPBS (high end soap) doesn't sud very much at all. neither does auto glyms.
All you need are lubricity and a PH balanced solution as was previously mentioned.
Suds = useless and mean nothing. People have been made to "think" that unless it 'suds up', you don't have enough or it's not a good solution.
As Jonno34 pointed out, what you want is a pH neutral solution with high lubricity. Water down some of FI's PPBS (Paint Pampering Body Shampoo) and run it through your finger tips, even diluted you can still tell the lubricity is very high.
I also wouldn't be putting my shampoo solution in a bucket either. The best way IMO is to have your buckets full of clean, hot water. Do a pre-rinse with PPBS solution and hot water and then i wash the car with a spray pack of washing solution. So as i go around i put a few sprays on the panel, a few sprays on the washing mitt. This way you have even coverage of washing solution a;ready on the panel you're about to clean.
I use an old brake-cleaner pump-pack as the pre-rinse dispenser and then an old 500ml FI trigger bottle for when i'm doing the main wash. Use less product, nice big even spray from the pack gives you good coverage of the panel and you keep the rinse water the way it should be, clean rinse water (well for as long as you can)
  • 4 weeks later...
Not necessarily true about the suds thing. I have recently bought a foam lance which hooks up to my Karcher pressure washer.
This creates a really nice thick foam that sits on the cars surface. The reason for this is to let the suds suck up any dust and dirt that isn't stuck to your paint.
You then rinse it off and begin your normal washing process whatever that may be.
I have found that this actually does work quite well, in reducing the small scratches you create when you are applying your normal wash with a microfibre mitt or sponge.
I wasn't really sold on it but i am def sold on it now.
lol science of washing a car...
Wanna know how I do it? $5 Armorall heavy duty wash and a $2 jumbo sponge. 4 caps in a regular bucket as you're filling it with water. Clears the sinuses and as a bonus it also cleans your car. Squirt panel with water, soap it up, squirt again.
Put some effort into waxing and the washing part won't need to be rocket science. On that note, I use a $7 paste wax that continues to bead after 6 months. Come at me premium products:
Pour the product/solution all over the car when wet " not mixed " Perfect system with no scratch
This is the best way by far , dont f...k around using a capful here and there = use at least a handful straight on the paint all over the car
  • 1 month later...
you quoted your own comment
-_-
Edited by w34ponGT
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
