hi all,
i was wondering if anyone know of a cheap transport mob to bring a non running r33 from caroline springs VIC to loganholme QLD.
The best price i got so far is about 1200.................gasp
so any help or ideas would be most appriciated.
thanx..
https://www.sau.com.au/forums/topic/406513-need-car-towed-from-vic-to-brissy/
that price seems dam good, Ive been getting qotes here in sydney, Cheapest is $400 for 152 KM.......
yea i spose it is, its jus alot of cash but with the price of fule these days i guess its bout right.
If you can get a car and trailer it would obviously be cheaper but massive drive. $1200 sounds pretty reasonable.
yea i ended up buying a cheap 97 land rover with gas running and with tow bar.
i will borrow my mates trailer next week n do the trip, once i'm back i will either flog off the land rover or keep it as a tow vehicle.
i did the sums and i'm gonna end up payin jus a lil bit over half of what i was quoted at the end of the trip, providing i flog off the land rover...
I paid $400 to get a flat-bed from byron to brisbane, about 200k's.1
So I'd say $1200 is pretty good.
yea your right, i spose i wasnt prepared to hear 12 to 15 hundred, would hate to kno what it costs brisbane to perth....lol
Well I ended up buying a 96 land rover disco V8i, 5speed, Dual fule, towbar for 2 grand.
I am going to borrow a mates trailer and go a pick up a GTS4 in Vic.
Once I get back to brissy, I have a mate who is going to buy the disco.
So at the end of the day getting my new car from Vic is going to only cost me the price of gas, If all goes well.
Edited by anikee
^^ These 4 words pretty much sum it up!
Good luck dude.
Well the luck lasted. 4 Days on the road, over 3,000km traveled, fule (LPG) cost under $750.
The original plan was to pick up a R33 GTS4 Rollin shell from Caroline Springs, VIC but after looking around for a donk, I found a RB25DE Motor a suburb away at MHC Performance for $500. So I got the rolling shell towed to MHC as we were heading down to VIC and Nat placed the motor in ready for us to pick up the car from his workshop when we arrived.
In the end it was a big saving to drive down and tow it myself, I was lucky in buying a reliable tow vehicle but also for my friend to buy it off me once my purpose done. (risky but paid off)
Edited by anikee
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
