Hey guys,
I have a series 2 R33 GTST that is annoying me..
Its 99% standard, just had all 4 discs machined and all 4 corners had new brake pads.
I drove the car for about 1000kms and it ran perfectly, then out of nowhere it started pulling hard to the left.
I had it checked out by a mechanic and discovered my caster bushes were buggered, so I had them replaced and got a four wheel alignment done. The car still pulls to the left just as bad.the person that did the wheel alignment said it might have a bent strutt.
I doubted this as the car started pulling out of nowhere on the freeway without hitting anything.
When braking real hard the car is perfectly straight and pulls up perfectly, but once the brakes are let off it will pull to the left again.
Any ideas or common faults? I was thinking a brake might not be fully releasing?
Please post any ideas :)
https://www.sau.com.au/forums/topic/406528-pulling-to-the-left-help/
OK, so obvious causes are tie rod ends, rack ends, and ball joints. Any one of these (if badly worn or damaged) can sit nicely in a given position whilst being wheel aligned, then shift to another position once the car is under way and has dynamic loads on the suspension. The same can be true of upper and lower control arm bushes.
It may also be at the back. If you have a stuffed HICAS tie rod end it will steer the car, although that usually doesn't feel like the front end pushing so much as just being strangely unstraight driving.
It also could have been a shit alignment initially.
Unfortunately for a simple thing, it often is done incorrectly. I've had some shocking alignments over years from reputable places even after I've told them what spec to align to;
1. They think they know better and don't do what you ask
2. Their equipment isn't calibrated correctly so it might be right on "paper", but the car is actually out.
You can tell the car isn't "right" by just driving 500m down the street. So that is also something else to consider as well.
Did you replace your caster bushes with adjustable items?
What are your wheel alignment specs?
Are your tyres directional and if not have you done a left to right swap?
Thanks for your ideas guys, you all raised valid points.. Tyre pressures all good, not sure on alignment specs, just standard I guess.
Non adjustable caster bushes fitted.
I have booked it into a different mechanic next week, so il be sure to update you after that.
Thanks again
It MIGHT also be the set-up itself
0 toe with equal caster (left/right) and lower offset wheels will also feel like it is pulling left pretty hard on our cambered roads.
ie. A 0 toe car with equal caster and flush wheel will follow the grooves in the road VERY closely. If you let the wheel go on almost any slightly cambered road will cause a obvious steer to the side of the road.
Normally the caster is split left/right to compensate somewhat.
Obviously this doesn't explain the sudden onset. For that I am thinking tyre wear.
Edited by simpletool
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
