Hey guys,
I have a series 2 R33 GTST that is annoying me..
Its 99% standard, just had all 4 discs machined and all 4 corners had new brake pads.
I drove the car for about 1000kms and it ran perfectly, then out of nowhere it started pulling hard to the left.
I had it checked out by a mechanic and discovered my caster bushes were buggered, so I had them replaced and got a four wheel alignment done. The car still pulls to the left just as bad.the person that did the wheel alignment said it might have a bent strutt.
I doubted this as the car started pulling out of nowhere on the freeway without hitting anything.
When braking real hard the car is perfectly straight and pulls up perfectly, but once the brakes are let off it will pull to the left again.
Any ideas or common faults? I was thinking a brake might not be fully releasing?
Please post any ideas :)
https://www.sau.com.au/forums/topic/406528-pulling-to-the-left-help/
OK, so obvious causes are tie rod ends, rack ends, and ball joints. Any one of these (if badly worn or damaged) can sit nicely in a given position whilst being wheel aligned, then shift to another position once the car is under way and has dynamic loads on the suspension. The same can be true of upper and lower control arm bushes.
It may also be at the back. If you have a stuffed HICAS tie rod end it will steer the car, although that usually doesn't feel like the front end pushing so much as just being strangely unstraight driving.
It also could have been a shit alignment initially.
Unfortunately for a simple thing, it often is done incorrectly. I've had some shocking alignments over years from reputable places even after I've told them what spec to align to;
1. They think they know better and don't do what you ask
2. Their equipment isn't calibrated correctly so it might be right on "paper", but the car is actually out.
You can tell the car isn't "right" by just driving 500m down the street. So that is also something else to consider as well.
Did you replace your caster bushes with adjustable items?
What are your wheel alignment specs?
Are your tyres directional and if not have you done a left to right swap?
Thanks for your ideas guys, you all raised valid points.. Tyre pressures all good, not sure on alignment specs, just standard I guess.
Non adjustable caster bushes fitted.
I have booked it into a different mechanic next week, so il be sure to update you after that.
Thanks again
It MIGHT also be the set-up itself
0 toe with equal caster (left/right) and lower offset wheels will also feel like it is pulling left pretty hard on our cambered roads.
ie. A 0 toe car with equal caster and flush wheel will follow the grooves in the road VERY closely. If you let the wheel go on almost any slightly cambered road will cause a obvious steer to the side of the road.
Normally the caster is split left/right to compensate somewhat.
Obviously this doesn't explain the sudden onset. For that I am thinking tyre wear.
Edited by simpletool
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
    • All of them are missing. You do not get much done with just AND, OR and NOT unfortunately. Ecumaster for example has a text based editor with at least 60+ math and logic instructions.
