Hey everyone,
Have a 97 R33 GTS full on povo spec, have a really irriating noise coming from front right suspension when I travel over uneven road surfaces in the road like manhole covers or uneven surfaces, doesn't make any noise on big bumps like speed bumps which I have a lot of where I live. I'm having trouble sussing out what is making the noise, from other research I have done I have found the upper arms are common to wear out, but I've already replaced the top outer just on the upright/j arm or what ever its called, and don't want to buy a arm as well and find that doesn't fix anything, I've had the prybar in there and can't feel any massive play where the upper arm bolts on to the body or any other bush. I'm beginning to think it could be the shock absorber, the inner boot is pretty destroyed, also wondered if all the speed bumps near my house could have caused some wear there.
Also replaced the tie rods recently as they had splits and had play.
Cheers if you got any ideas!
take it to pedders bloke. they did mine last week. and didnt even charge me the 14 bucks!
they will check everything including the brakes. better to have someone (sort of) qualified tell you than a keyboard ninja!
Ive had the $14 (I think) pedders inspection done in the past, and I have to say you get what you pay for. A very brief inspection, and consequently they missed many things. That was one experience at one shop, but keep in mind how much labour time theyre going to allocate to the job at any store.
Im not sure on the specific front suspension on your car, since mine in a 4WD it has some different components. Is there a control arm with ball joints on either end with the castor rod connected to that arm? Those ball joints wear and become loose in the socket over time. The castor bushing itself may have play in it.
The upper control arm bushings can crack and move laterally on the bolt resulting in metal on metal contact, that should be noticeable with a prybar though.
OP,
If you can't find a decent chassis and suspension shop yourself, find a good crash repairer and ask who they use to fix the problem cars that they just can't get to drive straight. There are always such cars, and there is always at least one ace suspension shop that they get sent to.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
