Ok so I've got a heap of R33 parts, I'll try to make the list as comprehensive as I can, but if you're after something thats not on the list feel free to msg me as I may have it. All parts located in western suburbs of Melb, happy to post anything under 15kg. Prices are cheap!
Can msg pics of anything.
0424999936
S2 Bonnet (white, straight) - 100
RHF guard (white, straight) - 70
Castor rod LHF - 40
Lower control arm RHF - 60
Castor rod brackets - 20 each
Instrument cluster (manual turbo 130ks) - 80
Drivers seat (bolster rip) - 20
Dash - 20
Power steering rack (recod complete from tie rod end to end) - 80
Interior parts - just ask, have heaps
Front subframe with engine mounts - 50
3 inch catback with single cannon 100db - 150
Gearbox mount with bracket - 40
Manual tailshaft - 60
5 stud conversion (100% complete hubs discs calipers brackets pads handbrake lever and cables) - 700
Injector loom - 20
Coil pack loom S2 - 20
Rear cradle - 80
Diff - 80
Rear swaybar with links - 20
rb25 clutch fan with sr20 fan blade - 10
Front window glass, drivers and passengers - 10 each
Radiator/condensor fan - 10
Standard dump pipe with O2 sensor - 20
Radiator with hoses - 40
FMIC with mounting bracket that replaces front reo, no piping - 100
Manual conversion parts
Pedals - 40
Clutch master cylinder - 40
Clutch metal hard lines - 20
Brake booster - 20
Brake master cylinder (abs) - 40
Drivers window reg with motor - 70
Passenger window reg with motor - 40
Passenger door trim complete - 20
Rear lower control arms - 20 each
Rear upper control arms - 20 each
Half shafts - 30 each
Drivers door (white) - 20
Front 5 stud turbo brake calipers - 180
Rear 5 stud setup (no handbrake cables) - 220
https://www.sau.com.au/forums/topic/406570-soooo-many-33-parts-vic/
  • Replies 68
sold most of the after market stuff off it. had greddy plenum nismo 555cc 2871r and te37s but it's all sold now. still got a really neat fmic with mounting kit for 100 bucks
yeah piping was to suit forward facing plenum unfortunately :(
everyone keep the pm, messages and calls coming! will update the list when things get picked up or sent out today
Updated list!!
Castor rod LHF - 40
Drivers seat (bolster rip) - SOLD
Dash - 20
5 stud conversion (100% complete hubs discs calipers brackets pads handbrake lever and cables) - SOLD
Injector loom - SOLD
Coil pack loom S2 - SOLD
Rear cradle - 80
Diff - SOLD
FMIC with mounting bracket that replaces front reo, no piping - SOLD
Pedals - 40
Brake booster - SOLD
Brake master cylinder (abs) - SOLD
Front 5 stud turbo brake calipers (missing a seal,caliper slide, and a couple of caliper bolts) - 60
Rear 5 stud setup (no handbrake cables) - SOLD
Updated list!!
S2 Bonnet (white, straight) - SOLD
Castor rod LHF - 40
S2 AFM air flow meter pink label - 60
Instrument cluster (manual turbo 130ks) - SOLD
Dash - 20
Rear cradle - 80
Diff - SOLD
Pedals - 40
Edited by filipovic
Updated list!! 19.8.2012
S2 Bonnet (white, perfect condition) - 150
RHF guard (white, straight) - 40
RHF guard (white, straight, holes drilled for cable ties) - 20
LHF guard (white, straight, holes drilled for cable ties) - 20
Grille (s2 white excellent condition) - 30
Despoilered boot (white, no holes, excellent condition) - 100
LH Taillight (white) - 40
RH Tailight (white) - 40
Spoiler (s2 in silver) - 50
RB25det s2 engine (complete with loom, ecu, turbo etc 100% complete, very low KM) - 1500
RB25det manual gearbox (very low KM) - 1300
Heater core - 40
Manual tailshaft x2 - 50 each
Front upper control arms - 10 each
Castor rod LHF x2 - 40
Castor rod RHF - 40
Lower control arm LHF - 60
Lower control arm RHF x2 - 60 each
Castor rod brackets x4 - 20 each
S2 AFM air flow meter pink label x2 - 50
Drivers seat (great condition) - 50
Passenger seat (great condition) - 40
Rear seats (great condition s2) - 60
Dash x2 - 20 each
Dash facia (good condition) - 40
Centre console x2 - 20 each
Gear surround (manual, boot in bad condition) - 20
Steering column lower trim - 20
Glovebox x2 - 20
Seatbelts - 15 each
Sunroof switch - 10
Interior map light - 20
Sunvisors - 10 each
Parcel shelf - 20
Power steering rack (tie rod end to tie rod end) - 50
Front subframe with engine mounts x2 - 50 each
Gearbox mount with bracket x2 - 40 each
Manual tailshaft x2 - 60 each
Rear cradle x2 - 60
Diff (lsd manual ratio) - 120
Diff - SOLD
Rear swaybar with links x2 - 20
rb25 clutch fan (trimmed for cooler piping) - 40
Radiator/condensor fan x2 - 10
Dump pipe with screamer and O2 sensor - 150
Radiator with hoses x2 - 40each
Pedals x2 - 40 each set
Clutch master cylinder x2 - 40 each
Clutch metal hard lines x2 - 20 each set
Brake Booster - 40
Brake master cylinder (non abs) - 60
Passenger door trim complete x2 - 20 each
Drivers door trim (without window switch) - 30
Half shafts x6 - 30 each
Passenger door (white) - 20
Updated list!! 25.8.2012
RHF guard (white, straight, holes drilled for cable ties) - SOLD
LHF guard (white, straight, holes drilled for cable ties) - SOLD
Headlight (s2 RHF missing the bracket where the grille clips) - 40
Headlight (s2 LHF broken on the bottom about 20c piece size missing) - 20
Front shocks (standard but great condition complete with springs) - 30 each
Coilovers (rear, pedders sports rider extreme x) - 300
350z wheels (pair of 17's no gutter rash) - 250
Steering wheel (s2 excellent condition) - 60
Steering wheel (rwc condition) - 20
Airbag (s2 excellent condition) x 2 - 20 each
Indiator stalk - 10
Wiper stalk - 10
Clock spring - 10
Airbag control unit - 10
Strut brace (front) - 50
Strut brace (rear) - 60
Wiper motor - 20
Steering column - 10
LH Taillight (white) - 20
RH Tailight (white) - 20
RB25det s2 engine (complete with loom, ecu, turbo etc 100% complete, very low KM) - SOLD
Heater core - 40
Castor rod RHF - 40
Dash x2 - 20 each
Gear surround - 20
Glovebox x2 - 20
Seatbelts - 15 each
Sunroof switch - 10
Sunvisors - 10 each
Parcel shelf - 20
Btrims - ask for price
Front subframe with engine mounts x2 - 40 each
Gearbox mount with bracket x2 - 30 each
Rear cradle x2 - 40 each
Diff - SOLD
rb25 clutch fan (trimmed for cooler piping) - SOLD
Radiator with hoses x2 - 30each
Brake Booster - 30
Brake master cylinder (non abs) - 50
Passenger door complete with glass and motor/reg (white) - 80
Front 5 stud turbo brake calipers (missing a seal,caliper slide, and a couple of caliper bolts) - SOLD
Hi mate, i'll grab: rb25 clutch fan with sr20 fan blade - 10
Providing the clutch hub is tight and in working order, and you'll post. (I only really need the viscous hub, don't mind if you send it without the blades).
Cheers.
