  • Replies 68
Updated list!! 31.8.2012
S2 Bonnet (white, straight) - SOLD
S2 Bonnet (white, perfect condition) - SOLD
RHF guard (white, straight) - SOLD
RHF guard (white, straight, holes drilled for cable ties) - SOLD
LHF guard (white, straight, holes drilled for cable ties) - SOLD
Grille (s2 white excellent condition) - SOLD
Headlight (s2 RHF missing the bracket where the grille clips) - 40
Headlight (s2 LHF broken on the bottom about 20c piece size missing) - 20
Despoilered boot (white, no holes, excellent condition) - 100
Front shocks (standard but great condition complete with springs) - 30 each
Coilovers (rear, pedders sports rider extreme x) - 300
V35 wheels (pair of 17's no gutter rash) - 200
Steering wheel (s2 excellent condition) - 60
Steering wheel (rwc condition) - 20
Airbag (s2 excellent condition) x 2 - 20 each
Indiator stalk - 10
Wiper stalk - 10
Clock spring - SOLD
Airbag control unit - 10
Strut brace (front) - SOLD
Strut brace (rear) - SOLD
Wiper motor - 20
Steering column - 10
LH Taillight (white) - SOLD
RH Tailight (white) - SOLD
Spoiler (s2 in silver) - 50
RB25det s2 engine (complete with loom, ecu, turbo etc 100% complete, very low KM) - SOLD
RB25det manual gearbox (very low KM) - SOLD
Heater core - 30
Manual tailshaft - 50
Front upper control arms - 10 each
Castor rod LHF x2 - 30
Castor rod RHF - 30
Lower control arm LHF - 60
Lower control arm RHF x2 - 60 each
Castor rod brackets x4 - 10 each
S2 AFM air flow meter pink label x2 - 50
Instrument cluster (manual turbo 130ks) - SOLD
Drivers seat (bolster rip) - SOLD
Drivers seat (great condition) - 50
Passenger seat (great condition) - 40
Rear seats (great condition s2) - 60
Dashboard - 20
Dash facia (good condition) - 40
Centre console - 20
Gear surround - SOLD
Steering column lower trim - 20
Glovebox x2 - 15
Seatbelts - 15 each
Sunroof switch - 10
Interior map light - 20
Sunvisors - 10 each
Parcel shelf - 20
Power steering rack (recod complete from tie rod end to end) - 80
Power steering rack (tie rod end to tie rod end) - 30
Interior parts - just ask, have heaps
Front subframe with engine mounts x2 - 40 each
3 inch catback with single cannon 100db - 150
Gearbox mount with bracket - 30
5 stud conversion (100% complete hubs discs calipers brackets pads handbrake lever and cables) - 700
5 stud conversion (100% complete hubs discs calipers brackets pads handbrake lever and cables) - SOLD
Injector loom - SOLD
Coil pack loom S2 - SOLD
Rear cradle x2 - 40 each
Diff (lsd manual ratio) - 120
Diff - SOLD
Rear swaybar with links x2 - 20
rb25 clutch fan with sr20 fan blade - SOLD
rb25 clutch fan (trimmed for cooler piping) - SOLD
Front window glass, drivers and passengers - 10 each
Radiator/condensor fan x2 - 10
Standard dump pipe with O2 sensor - 20
Dump pipe with screamer and O2 sensor - 150
Radiator with hoses x2 - 30each
FMIC with mounting bracket that replaces front reo, no piping - SOLD
Manual conversion parts
Pedals x2 - 40 each set
Clutch master cylinder x2 - 40 each
Clutch metal hard lines x2 - 20 each set
Brake Booster - 30
Brake master cylinder (non abs) - 50
Brake booster - SOLD
Brake master cylinder (abs) - SOLD
Drivers window reg with motor - 70
Passenger window reg with motor - 40
Passenger door trim complete x2 - 20 each
Drivers door trim (without window switch) - 30
Rear lower control arms - 10 each
Rear upper control arms - 10 each
Half shafts x6 - 30 each
Drivers door (white) - 20
Passenger door complete with glass and motor/reg (white) - 80
Front 5 stud turbo brake calipers (missing a seal,caliper slide, and a couple of caliper bolts) - SOLD
Rear 5 stud setup (no handbrake cables) - SOLD
Updated list!! 2.9.2012
Indiator stalk - 10
Wiper stalk - 10
Wiper motor - 20
Heater core - 30
Castor rod RHF - 30
Dashboard - 20
Steering column lower trim - 10
Glovebox x2 - 15
Seatbelts - 15 each
Interior front map light - 20
Parcel shelf - 20
Pedals - 40 each set
Clutch master cylinder - 40
Clutch metal hard line - 20
Brake Booster - 30
Updated list!! 15.9.2012
Indiator stalk - 10
Wiper stalk - 10
Wiper motor - 20
Heater core - 30
Castor rod RHF - 30
Dashboard - 20
Glovebox x2 - 15
Seatbelts - 15 each
Parcel shelf - 20
Rear cradle x2 - 30 each
Brake Booster - 30
hey after rear lower control arms.
Have read that s14 & r33 rear LCA's are the same.
any rust? Balljoint/boot all good?
Can you send me a pic?
and lastly where in the west are you located?
cheers.
Updated list!! 25.9.2012
V35 wheels (pair of 17's no gutter rash) - 150
Indiator stalk - 10
Wiper stalk - 10
Wiper motor - 20
Heater core - 30
Castor rod LHF - 30
Dashboard - 20
Glovebox x2 - 15
Parcel shelf - 20
5 stud conversion (100% complete hubs discs calipers brackets pads handbrake lever and cables) - 600
Brake Booster - 30
Updated list!! 4.10.2012
BLITZ fmic return flow (perfect, almost new with piping) - 450
Apexi PowerFC to suit r33 gtst with hand controller (perfect condition) - 1200
Apexi SAFC2 - $200
Autometer boost guage - 50
Apexi turbo timer - 50
HKS turbo timer - 50
S1 Bonnet (black, perfect condition) - 120
RHF guard (black, perfect condition) - 70
LHF guard (black, perfect condition) - 70
Headlight (s1 RHF perfect condition) - 200
Headlight (s1 LHF has some damage, ask for pics) - 50
Bootlid (s1 spoiler in black, great condition) - 20
Front shocks (king springs very low great condition complete with springs) - 50 each
Rear shocks (standard but great condition complete with springs) - 50 each
Standard r33 wheels (heaps in stock) - make offer
Indiator stalk - 10
Wiper stalk - 10
Wiper motor - 20
LH Taillight (black) - 40
RH Tailight (black) - 40
RB25det s1 engine (complete with loom, ecu, turbo etc 100% complete, 180k km) - 1500
RB25det manual gearbox - SOLD
Heater core - 30
Castor rod RHF - 30
Lower control arm RHF - 60
S1 AFM air flow meter green label - 60
Drivers seat (bolster rip) - 20
Dashboard - 20
Dash facia ([ainted, good condition) - 20
Centre console - 20
Gear surround (painted, good condtion) - 20
Glovebox x2 - 15
Seatbelts - 15 each
Sunroof switch - 10
Sunvisors - 10 each
Parcel shelf - 20
Power steering rack (tie rod end to tie rod end) - 40
Rear cradle x2 - 20 each
Rear swaybar with links - 20
Brake Booster - 30
Drivers window switch (11 pin and 12 pin in stock) - 100
Passenger door complete with glass and motor/reg (black) - 80
Edited by filipovic
Updated 12.10.12
Apexi PowerFC to suit r33 gtst with hand controller (perfect condition) - 1000
Apexi SAFC2 - $200
S1 Bonnet (grey, perfect condition) - 120
RHF guard s1 (grey, perfect condition) - 70
LHF guard s1 (black, perfect condition) - 70
Bootlid (s1 spoiler in grey, great condition) - 20
Full set of koni yellow shocks with king springs - 250
Front shocks (standard but great condition complete with springs) - 20 each
Front shocks (king springs very low great condition complete with springs) - 30 each
Rear shocks (standard but great condition complete with springs) - 20 each
Steering wheel (s2 rwc condition) - 20
Steering wheel (s1 good condition) - 40
Dash facia (painted white) - 20
Gear surround (painted white) - 15
Gear surround (good condition) - 30
Nismo gear surround and handbrake leathers (brand new) - 50
Cusco front strut brace - 80
Standard exhaust for EPA - 120
Catback 2.5 inch single cannon - 80
Indiator stalk - 10
Wiper stalk - 10
Wiper motor - 20
LH Taillight (grey) - 30
RH Tailight (grey) - 30
RB25det s1 engine (complete with loom, ecu, turbo etc 100% complete, 180k km) - 1300
RB25det manual gearbox - 1200
Heater core - 30
Manual tailshaft - 40
Castor rod LHF - 30
Castor rod RHF - 30
Castor rod brackets - 10 each
S2 AFM air flow meter pink label - 50
Drivers seat - 40
Dashboard - 20
Dash facia (painted, good condition) - 20
Centre console - 20
Glovebox - 15
Seatbelts - 15 each
Sunroof switch - 10
Sunvisors - 10 each
Parcel shelf - 20
Jack - 20
Front subframe with engine mounts - 40 each
3 inch catback with single cannon 100db - 120
5 stud conversion (100% complete hubs discs calipers brackets pads handbrake lever and cables) - 500
Rear cradle - 20 each
Diff (lsd manual ratio) - 100
Dump pipe with screamer and O2 sensor - 100
Radiator with hoses - 30
Brake Booster - 30
Brake master cylinder (non abs) - 40
Passenger door trim complete - 20 each
Drivers door trim (without window switch) - 20
Half shafts x6 - 20 each
Intake manifold - 50
Throttle body s1 - 40
Space savers - 20 each
18 inch tyres kuhmo 95% tread - 100 the pair
19 inch tyres 245s michelin pilotsport 70% tread - 100 the pair
  • 4 weeks later...
Updated 12.11.12
FMIC with cooler piping (over the fan, aluminium) - 250
Standard side mount cooler - 20
Coilovers (unknown brand, height adjustable, no leaks or knocks, anodized blue and red) - 450
Standard catback with a cannon - 40
S1 Bonnet (red, perfect condition) - 120
RHF guard s1 (black, perfect condition) - 70
Headlight (s1 LHF perfect) - 180
Headlight (s1 RHF perfect) - 180
Bootlid (s1 spoiler in red, great condition) - 20
Airbag (s2 excellent condition) - 20
Dash facia (good condition) - 50
Indiator stalk - 10
Wiper stalk - 10
Wiper motor - 20
RH Tailight (black) - 30
LH Tailight (black) - 30
RB25det s1 engine (complete with loom, ecu, turbo etc 100% complete, 130k km) - 1350
RB25det s2 engine (complete with loom, ecu, turbo etc 100% complete, 80k km) - 1200
Heater core - 30
Castor rod LHF - 30
Castor rod RHF - 30
Lower control arm LHF - 50
Lower control arm RHF - 50
S1 AFM air flow meter green label - 50
Drivers seat (perfect condition no rips) - 40
Passenger seat (great condition) - 20
Rear seats (great condition s2) - 30
Dashboard - 20
Centre console - 20
Glovebox - 15
Drivers seatbelt - 40
Seatbelts - 20
Sunroof switch - 10
Sunvisors - 10 each
Parcel shelf - 20
Jack - 20
Front subframe - 40
3 inch full exhaust dump pipe back with hiflow cat - 350
5 stud conversion (100% complete hubs discs calipers brackets pads handbrake lever and cables) - 350
Clutch master cylinder - 30
Clutch metal hard lines - 20 each set
Brake Booster - 20
Brake master cylinder (abs) - 50
Half shafts - 20 each
Drivers door (red) - 20
Passenger door complete with glass and motor/reg (red) - 80
Intake manifold - 40
Updated 16.11.12
Indiator stalk - 10
Wiper stalk - 10
Wiper motor - 20
Heater core - 30
Castor rod LHF - 30
Castor rod RHF - 30
Dashboard - 40
Centre console - 20
Glovebox - 15
Seatbelts - 20
Sunroof switch - 10
Sunvisors - 10 each
Parcel shelf - 20
Jack - 20
Front subframe - 40
Brake Booster - 20
Drivers window switch (8,11 and 12 pin in stock) - 100
18 inch tyre kuhmo 95% tread - 30
  • 1 month later...
bump, heaps more parts here than is on the list, msg me with whatever you're after.
- alloy radiator with thermo, 60mm - $180
- rb25det manual gearbox - $1300
- veliside gearknob - $50
- enkei rp01's - $900
- r33 stockies with tyres - $35 each
- momo steering wheel with boss kit - $180
also stripping a s2 rb25det all parts available off the motor which has done 112,000km
