Hi All,
Just enquring to what others have done to regards to lowering springs for a PM35 is there an off the shelf option?, only looking at lowering it 40mm. Being in NZ not that keen to go down the coilover route if I can help it as it requires certification to be road legal.
Either NZ or OZ for options is fine as getting them over here isnt a problem.
Cheers, 2dr
https://www.sau.com.au/forums/topic/406571-pm35-06/
I have same car PM 06 in Wellywood, Haven't seen any for sale since I was lucky and got some Nismo springs off trademe $250 from a NM went about 30mm lower, a guy had them on his wag down south, said they were too hard, they are about 20% firmer than standard, he had 20's on his thats why it was hard. FYI the Nismo's have ten coils and are thicker than the stock 7 colis.
https://www.sau.com.au/forums/topic/406571-pm35-06/#findComment-6478983
Thanks for the reply, are the 4wd and rwd drive version interchange able I tried to get some teins but was told they dont make them for the PM35 only nm35.
Cheers, 2dr
No, 4wd and Rwd have different front mounts
You can see the difference if you scroll down to the Nismo suspension in this old thread
http://www.skylinesaustralia.com/forums/topic/267775-m35-aftermarket-suspension
https://www.sau.com.au/forums/topic/406571-pm35-06/#findComment-6479597
    • Man, you guys are like an all knowing encyclopedia.. how do you guys know how to fix everything?? but thanks. i will try to trace this wiring today. What is this globe thing you are referring too? Globe Power Supply? Are you referring to the light bulb?
    • Vinyl paint always ends up coming off interior trim and looking like arse. For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
