hey guys,
well my new exhaust arrived last night - JIC Magic Spartan exhaust.
I'm running this and an N*Power Y-pipe. Got it fitted today,
fit and finish seem quite good, one tip protrudes slightly further than the other, but nothing rubs or clangs.
It isn't ridiculously loud (despite the fact that the rear muffler is pretty much straight through, and there is no other muffler!), but it isn't as quiet as the Legalis R.
There isn't any drone, except at between 2 and 2.5k.... (DAMNIT!) , I am planning to add a three inch resonator to hopefully cut this out (in a similar position to where the standard exhaust has the smaller muffler)
I'm pretty happy with it, total cost is 800 including delivery to my door from the US.
Haven't taken any pictures of it on the car, but it looks good!
https://www.sau.com.au/forums/topic/406602-jic-magic-exhaust-v35-coupe/
Thanks mate, will do when I get my phone repaired (broke the camera the other week).
Other than that, I'm trying to work out how to kill the drone a bit. (between 2 and 2.5k rpms)
Not sure if its my cheap Y-pipe with the thin steel walls (The JIC has very thick steel in the piping... unlike the Y-pipe where it is thin), or if I need an extra resonator or straight through muffler installed before the rear muffler.
One thing I have learned with previous cars is that exhaust shops don't seem to know how to get rid of drone unless you are a commodore, falcon or excel (which I suppose is probably the average exhaust shops bread and butter)
Don't forget the good ol' Charades and Swifts... Hectic brah!
  • 3 weeks later...
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
