[Fs] [Inner Sydney] Honda Prelude Vtir - Midnight Blue - Vtec Engine - Super Fast !
Massive redevelopment. I believe they built up an earth mount / wall between the track and the complainers. D probably has more info on what they did here. They now run it both directions also which is cool.
Nice. Did they sort out the neighbours? Or are they running more restricted? Plenty of old cheap navaras to be had on market place, once you sort through the "rare, only 5326 made, I know what I've got" crowd.
I definitely wouldn't say no. Honestly, if I had the funds, I'm very interested in a GU ute.
I guess that wasn't exactly a bolt in swap Generally the best option is just not to go too low since you can get reasonable handling out of an R chassis at a little below factory height. If you want to keep going down, there are ball joint spacers for the bottom of the hub, not really much you can do at the top without going very custom (which...you already have...)
Good to see it has a front driveshaft
