  • Replies 46
  • 1 month later...
Hey all, since there's been a lot talk and interested in Motordyne products, particularly the Shockwave TDX2 Cat-Back Exhaust System. I've seeked a quote for the Shockwave TDX2 Cat-Back Exhaust System including shipping and so on, based on a 10 unit purchase.
Also there are a number of other Motordyne products that you may be interested in, such as ART Pipes, XYZ Pipe and Sway Bars. So express your interest via private message in which product you want by next Thursday (18th October 2012), so I'm able to provide the group buy facilitator the exact numbers to get a quote for.
Now the way the shipping will probably happen is that each buyer will provide the shipping address and the shipping quote will be individual to each buyer and the items will be shipped directly to the buyer (unless you can team up with someone in your own city), this will save cost on double handling. Note, that most of the savings will be on the units itself and there may be savings on the shipping too.
As always with group buys, the more buyers there is, the lesser the cost will be to each person on the units. So if you are intending to get these down the track, I suggest you get onboard and if you don't have the funds then borrow some money, as this will probably save you a fair bit down the track.
Looking to close the group buy and make payements by Thursday on the 1st November 2012, as there will be lead time on some of the products and shipping time. Also, we would want to get in before December comes, as they will be delays with holidays and the amount of shipping that occurs with the Christmas period.
@81gSKY would you know a rough estimate on how much we can each save in a group buy of 10 or a group buy of 20? Did Tony or a rep from Motordyne go through a ballpark figure with you?
Was looking to buy the tdx2 and the ART pipe early next year but if i can save abit then i might jump in and do the group buy.
Sorry, I haven't gotten a quote yet, that's why I need the quantity on each item and the shipping addresses by next thursday and I will the quote accordingly.
But just take this as a reference point from when I got a solo quote from Tony (Motordyne) a while ago, "$1,635 USD for the unit, $565.23 USD for shipping through FedEx International Economy (arrival 5 business days) and additional for taxes".
Edited by 81gSKy
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
