Is someone able to give me the correct part numbers for all three drive belts for my S2 Stagea (aircon, alternator, power steering)
Recently as part of my 100,000k service I bought a set of drive belts. The local gates dealer supplied me with
4PK835R
4K865R
4PK925R
(I ordered gates racing belts)
When my mechanic did the service he said they didn't fit and the belts on it are at the end of the adjustment. The belts on it currently he said are
4PK865
4PK890
4PK910
I had a quick look on just jap and the numbers they list are
3PK840
4PK855
4PK915
Which are the correct numbers? Please help, no searching is coming up with anything lol
https://www.sau.com.au/forums/topic/406663-rb25det-neo-belts/
The 4 stands for 4 ridges/ribs. The last numbers stand for the circumference.
If the mechanic said to get 10mm shorter
4PK865 = 4PK855
4PK890 = 4PK880
4PK910 = 4PK900
Mine were replaced a while ago. I just checked them and they are the same as what the mechanic told you you have on your car.
I just noticed something too ( see attached pic) - On the Alternator/Waterpump Belt (890) I am only using up less than 10mm of the adjustment and have a shitload to go. A 4PK880 would be a bitch to put on.I would say your mech. wants 10mm shorter because the current ones are stretched. That's just what happens over time.
Basically, Do what KiwiRS4T said :)
Yeah that's why the mechanic said its near the end of the adjustment. The belt shop gave me a 4PK925R to fit where a 4PK910 should go so he couldnt adjust it enought to fit.
It does seem that the belts currently on the car are the ones I need and are the standard stagea length because they're the same as what's on other peoples stagea's
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
