well if he doesn't its gonna cost him his business! he said he has done a few before, and im leaving him with my old man. who will watch him like an eagle the whole time!
Just make sure what ever pot he is doing that the piston is at TDC or else it's harder to clean or know what's in there, btw is it just slightly cross threaded or fully f*ked? Cuz he should really only need to tap it not put a hellicoil through it.
https://www.sau.com.au/forums/topic/406673-ohhh-no/page/2/#findComment-6488611
he tapped it. said the spark plug wasn't going all the way would have lost a lot of compression and the coil pack would have misfired.
only charged 100 bucks. standard call out fee i think. made sure there was no swarf in the piston and then made sure the spark plug went all the way in and correctly. ill let you know how she drives Monday.
but up to now i highly recommend this guy. 100 bucks is a lot cheaper than replacing broken coil pack every week!
plus he drove from narre warren (i think) to hastings and was here at 7:30 in the morning.
https://www.sau.com.au/forums/topic/406673-ohhh-no/page/2/#findComment-6491216
How will it damage the coil? U will only loose compression. Good to hear that it's all fixed
https://www.sau.com.au/forums/topic/406673-ohhh-no/page/2/#findComment-6491383
I had this issue last year. Ended up buying one of these.
http://www.vektools.com.au/powerbuilt-hand-tools/powerbuilt-14mm-backtap-spark-plug-thread-repair-tool-p-6182.html
Made fixing the thread easy as and with a decent amount of grease on the tap no worries about any metal getting in the cylinder at all. Cheaper than thread bloke and you'll always have it handy too.
https://www.sau.com.au/forums/topic/406673-ohhh-no/page/2/#findComment-6501687
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
    • UPDATE: was able to have the bracket repaired and base repaired, seat is like new now ;)
    • I was going to say it looks right out of Gran Turismo photoshoot when you just buy the car. (in a good way)
