Basically parting out most of my silvia track car and going in a new direction. This set up made a reliable 255kw atw all day every day, never had an engine problem. Engine has travelled very few kms since i pulled it from a front cut in 2009 maybe 6 - 10 events a year. Has been tuned by chea at powertune and jim at croydon racing developments and both said that it tuned like a fresh motor. Was tuned for response opposed to top end power. Slightly negotiable on items if sold as a whole package. other wise not negotiable.
ring or sms me on 0418772525, dont check the forums much
93 redtop sr20det 85,000 kms
-copy greddy inlet manifold
-BC 264 in & ex cams
-BC valve springs
-BC titanium retainers
-Moroso aluminium sump
-nismo thermostat
-speedflow dash fittings fitted to rocker covers
-alloy pulley kit
-Greddy oil cap
-oil relocator block
$1500
Haltech e11v2 with patch loom to suit red top sr20det
-currently has tune to suit this package on it
-air temp sensor
-3 bar map sensor
$1100
Splitfire coil packs to suit redtop sr20
$350
Sard fuel rail with sard green 800cc injectors
$500
Motorsport connections catch can setup to suit
-speedflow fittings
-push on hose and heat shielding
-drains to sump
$180
Trust Td06 20g kit
-td0620g turbo
-genuine braced greddy high mount manifold
-genuine trust 50mm external gate and screamer
-oil lines to suit
-braided vacuum lines
-best turbo for sr20s bar none
$2000
OS Giken twin plate clutch r2cd
-awesome clutch
-good condition
-never slipped
-never had any problems
$1500
Z32 gearbox conversion
-1 manual z32 gearbox
-Thicker sr20 auto bell housing cut and shut by Stewart Wilkins motorsports
-gearbox mount to suit s13
-shifter mount shortened so it pops up in the standard position
-gearbox is a bit notchy into third, apparently pretty common with z32s
-$900
Can do all of the above items in a package deal for $7600
standard z32 gearbox
-had as spare and never used it
-been sitting in my shed for 2 years
-never used but selects gears by hand fine
$500
Gtir quad throttle bodies
-came off a wreck with 28000km's
-convert your sr to quads
$450
Standard sr intake manifold
-combine with above manifold to convert runners
$50
Rb25 NEO motor
-no manifolds
-comes with power steering pump
-alternator
-was going to use in a project but haven’t ended up using it
-came out of a rear ended low km r34
$1000
Blitz alloy GTR individual throttle body adapter plates to suit rb25
-convert GTR itb's to your rb25
-extremely rare
$550
GTR individual throttles
-everything from head to plenum
-great condition
-combine with plates above for awesome response on your rb25
$500
Rb25 NEO gearbox
-low kms
-comes with shifter
-best rb box available
$1350
full 7 pointsafetyl 21 bolt in cage to suit sunroof s13
-comes with bolts and plates
-side intrusion bars
$670
3 greddy gauges
- water temp
- boost
-exhaust temp
$250
3 sabre gauges
-fuel pressure
-oil pressure
-oil temp
$100
hey mate, i am pretty sure they are sold. Waiting to confirm this saturday. I havent fitted them before.They dont make these anymore and i have only ever seen one other set for sale in Australia........ there the business and they are also on ebay at the moemnt
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
