Hi Guys,
I joined the forum few days back, reading and hoping to find a answer to my Delmer.
I currently am doing a full resto on a 69 dodge phoenix now for over a year and i am needing a break on it, so i decided to buy a cheap skyline and go from there.
Too cut a long story short, I bought a immaculate rolling shell R33 GTS4 and all that it requires is motor, box n ecu, thinking how hard is it to slip an engine n box...........well
After trying to find anything that could help me out, i got totally confuddelled :wacko: ...but from what I have read I have one of the less desirable skylines.
All I would like to do is get the car back running in original set up and everything to work as it was before removal of old motor n box.
Now do i need to find a replacement from another R33 GTS4 or Can i source a RB25DE form another car?
what about ecu? do i use the one from replacement motor or find one from a GTS4?
I need a gearbox, can i use one out of a GTS T or from any other model.
I know some of my questions might be stupid to some but i do apologize, so if anyone can throw me a link, phone number or any advice it would be most appreciated.post-97245-0-73837000-1344527018_thumb.jpgpost-97245-0-77517700-1344527056_thumb.jpg
In my view the GTS4 is one of the more desirable Skylines (poormans GTR). Importantly it is awd.
Ideally you would get an RB26 and GTR gearbox or second best an awd Stagea Neo turbo engine and GTR gearbox or finally a S1 awd Stagea( R33 S2 RB25DET) motor and GTR gearbox. In each case you would need the ecu and loom to go with the motor.
If you really don't want a turbo you would need a Stagea awd RB25DE (fairly rare in Aussie - dime a dozen in NZ) or an original GTS4 engine.
Putting an rb26 in mime, stock box. Or another great option is the neo 25det. Both a straight drop in but custom piping needed, a stud conversion of not already done. You mentioned de motors? Don't want turbo?
Choose Neo before GTR motor. Less fuss, still easy to make power later if wanted, variable cam timing to put some torque into the bottom end. Much cheaper.
But.... be aware that a conversion to Turbo will require a brake upgrade to be legal, means going over the pits etc etc. If you were to drop an original GTS4 motor into it you will have an easier time of getting it back on the road.
Gts4 came factory turbo, no need for engineer cirt at all.
Not quite true. If it was an NA, then it will have NA brakes. You cannot legally put a turbo in without upgrading brakes. In SA, that means at a minimum it has to go to Regency for ID and roadworthy inspections in order to "complete" the engine swap - no engineer required, but the inspection is compulsory. In some other states, a brake swap is a trigger for an engineer's report, even if other versions of the same car had the required brakes.
Even an RB25DET into R32 (from RB20DET starting point) requires the R33 brakes.
Thanx for the reply KiwiRS4T , ok thats givem me an idea. i would go for the easiest option and try and source a GTS4 donk n box.
Choose Neo before GTR motor. Less fuss, still easy to make power later if wanted, variable cam timing to put some torque into the bottom end. Much cheaper. But.... be aware that a conversion to Turbo will require a brake upgrade to be legal, means going over the pits etc etc. If you were to drop an original GTS4 motor into it you will have an easier time of getting it back on the road.
yeah going to original setup is the go, way easier n cheaper i think. i can always then sell it and buy something already with a turbo ;later if i like.
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
