Guest jimmyd17
93 camry??? are u ppl insane? they have to be the ugliest piece of crap on the roads.. they look like an over-inflated marshmellow, they are a horrible car to drive with unresponsive steering, not to mention how completely gutless they are... even the V6's are cops. any of the other cars seem fine though. i'd go a N14 pulsar for 6K
  • Replies 42
Nissan Bluebird. theyre around $6000 - $11000
the SSS 4WD Attesa sr20det are around 11k and up i think
found a 1994 NISSAN BLUEBIRD TI
$4,990
Manual
Sedan
Km: 233,518
Colour: Burgundy
10/1994. 2.4 litre. With air conditioning, power steering, electric mirrors/windows, cruise control, factory alloys. Drives excellent.
carsales - bluebird
the rego was coming up and the tyres need changing etc and i need to come with 3000 dollars and need to sell but once i get my finaice stable i will buy another one now i just need a car that can drive and damn reliable as i dont want to spend anything on this car
i have found daihatsu terios that look like a fun car to drive and a suzuki vitara maybe anyone know about those cars which one is faster
agreed, except get a U12 trx instead of an n14 :(
Dude, stay away from anything that is performance orineted - it woudl have been thrashed and in need of dollars spending. I like your idea on the camery or magna, but they are just so dull... I would go a Mazda 626, or the telstar cousin - but get a manual (better on fuel).
Anything that is too small will be a bitch to live with.
http://forums.fastfours.com.au/viewtopic.php?t=78122
1987 ae82 twin cam seca
resprayed toyota factory red ( 12 months old )
185,000kms
exhaust
lowered
updated ae92 interior
standard alloys
4 wheel disc
Mar 23 2005 rego
jvc cd player
kenwood front 4 inch speakers
jbl rear 5x7s
mechanically sound
rebuilt rear calipers, handbrake, new rack ends, dizzy
have receipts for $2000
$3500 ONO
sydney
www.cottee.net/gallery1.html
Car is in good condition. Reason for sale - Loss of license; no P plates + using handheld mobile
The R31. Fuel economy is OK. between 8 and 12l per 100/km on average stop start driving.
The RB30E engine is tough as nails. Plenty have hit 300,000ks and still going strong. Many have also strapped turbos to the n/a motor with over 200,000ks and they still survive.
The downside is they are a dated design if you wanted a more modern look.
The words "RX7" & "Reliable" in the same sentence
:(:D:rant:
They are actually reliable despite what people think, like every other car if maintaned properly and not heavily modified they are a good thing. And the little 12A's in the S1,2,3s are good for 200-250,000kms. But if the maintenance wasn't up to scratch look out...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
