Will swap for VX/VY/VZ Holden Commodore
$4500 ONO
1993 Toyota Corolla Levin (AE101) GT Apex Coupe (Japanese Import) Silver Top
The later Corolla LEVIN Apex GT's are almost unknown amongst the range of used imports that have come into Australia from Japan over the past few years.
"Silvertop" 20 Valve
S2 version with improved inlet manifold shape - The 20 Valve engines evolved during their production life with changes of a generally minor nature involving principally, a reduction in reciprocating mass ( flywheel, conrods, etc) airflow (manifold shape, valve size, throttle body) piston design and injector capacity.
Front suspension is squeaky.
Selling because bought a boat but need a car to tow boat with, looking for VX/VY/VZ commodore
    • I'll measure it up at the lowest point later and post it up Currently painting, with the oven all warmed up to 93°c
    • How much clearance is under the car? We have speed humps being added everywhere around me. Faster than they fix the potholes, thats for sure.
    • After some googling of various websites IRT the best ride height for correct geometry I ended up going,  hub to guard, 330mm in the rear and 345 at the front, these heights came from Flyin' Miata in the states as what they recommend (13" rear, 13.5" front) The rear needed to only come up 5mm, but the front came up 15mm Overall it is around a 25mm drop from OEM ride height, doesn't look all 4x4, and hopefully should be enough height to clear those pesky speed humps I have lost around 0.5° camber on the front, and around 0.2° in the rear, I have no idea about what it did to toe settings so I'll look at a new alignment next week to get it set up how I want, zero rear and a little in at the front I've also stripped the new intake and am currently cleaning and preparing the alloy for some paint, I've headed into work to do it as I can use the ovens in the soils lab to cure the wrinkle paint at 90°c Jackie has banned me from using the oven at home for stuff like this....🤣
    • At my age, 59, I'm in bed by 20:30 nowadays 😴 I'm pretty much a solar powered device, powering up at first light, and powering down when the sun goes down 🤣 Oh to be young again.....
