My 2cents:
* All GTR's look awesome including the 33
* 32's & 33's non GTR look pretty bog boring without some Bolt on bits
* 34's look sweet regardless
I do want to add that IMO standard r33 gtst's are the least attractive option which somehow makes the 33 GTR's look extra nice by comparison.
You've gotta say that Stagea's are more about practicality with power & handling than about looks, but for a wagon, they look good enough!
I like my S1, it doesn't look like a racecar, but I dont think its ugly either and it doesnt attract unwanted attention :D
though it is very hard to get a good picture of it, get the wrong angle and it looks like balls
All that said I will probably kit it oneday....
Have a look in your rear view mirror next time you have a 32 behind you and let me know if you can tell wether its an early 90's laser or a 32. I cant.
It'll help Noel if you can find the rear view mirror ;)
Please don't mix up GTR and GTS appearance together.
I'd agree the series 1 r33 gts isn't that spectacular with it's low duck wing and bad front end, not to mention the interior but r32 gts isn't far behind. r34 gtt in stock form isn't great either. narrow front fenders and boxy rear end.
I'm sure a Series 3 R33 GTR in Midnight purple does not lose to a R32 OR R34.
BTW, despite what many think, r33 gtr isn't the heaviest. R34 GTR V-spec weights 1560kg. 33 V-spec only weights 1540kg.
Edited by Mingy
S1 with nice wheels, lowered, bomex type grill, duck wing and nice front mount (without chopping up the front bar) looks very tasteful
so in other words change everything about a s1 that makes it a s1 and itl look alright..
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
