My 2cents:
* All GTR's look awesome including the 33
* 32's & 33's non GTR look pretty bog boring without some Bolt on bits
* 34's look sweet regardless
I do want to add that IMO standard r33 gtst's are the least attractive option which somehow makes the 33 GTR's look extra nice by comparison.
You've gotta say that Stagea's are more about practicality with power & handling than about looks, but for a wagon, they look good enough!
I like my S1, it doesn't look like a racecar, but I dont think its ugly either and it doesnt attract unwanted attention :D
though it is very hard to get a good picture of it, get the wrong angle and it looks like balls
All that said I will probably kit it oneday....
Have a look in your rear view mirror next time you have a 32 behind you and let me know if you can tell wether its an early 90's laser or a 32. I cant.
It'll help Noel if you can find the rear view mirror ;)
Please don't mix up GTR and GTS appearance together.
I'd agree the series 1 r33 gts isn't that spectacular with it's low duck wing and bad front end, not to mention the interior but r32 gts isn't far behind. r34 gtt in stock form isn't great either. narrow front fenders and boxy rear end.
I'm sure a Series 3 R33 GTR in Midnight purple does not lose to a R32 OR R34.
BTW, despite what many think, r33 gtr isn't the heaviest. R34 GTR V-spec weights 1560kg. 33 V-spec only weights 1540kg.
Edited by Mingy
S1 with nice wheels, lowered, bomex type grill, duck wing and nice front mount (without chopping up the front bar) looks very tasteful
so in other words change everything about a s1 that makes it a s1 and itl look alright..
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
