Hi all,
My current headlights look a little dated cos they're cloudy and not sparkling like they used to.
i'm also looking for clear indicator lenses (possibly white fog lights too).
I think this will seriously improve the look of the car and something I really want to do.
Is it best to source new plastic for the headlights so it's brand spanking? Anyone had experience with this?
Not having much luck finding any new ones.
I had this problem on my 33.
All you have to do is get metal polish and rub down your headlights with it. It will clear them right up. Obviously its not a permanent fix, but then again getting new headlights isn't permanent either.
The clouding/yellowing of your headlights comes from oxidization basically the water hits your headlights and dries up leaving a residue/rusting the plastic. Once you cut and polish it, it goes away for awhile say a year or two then just do it again. Simple, easy and cheap way to fix it.
Don't waste your money on new headlights if you don't have cracks in yours.. unless your printing money, in that case send me some haha.
I'll take some too :)
But yeah they are correct, polishing works a treat and is simple. What I have also done in the past which gives a even longer term answer is given them a light sand then spray a Quick clear coat over them, that gives them an awesome long lasting shine (sounds like a tooth past ad)
it depends on the level of oxidisation as to whether the lense can be saved.
meguiars do a headlight restoration kit, seen it done on an r34 and looks good
i did a DIY version on my v35 - 1000 then 1500 grit wet rub with soapy water, plastic polish, then plastic protector. apart from needing to repolish the headlights once a month, its perfect.
tried both techniques on a 2003 holden astra - fail. those could not be saved.
The worst thing about those kits are the fact that most of them dont have a UV protectant which i whatcuases the oxidisation and yellow in the first place.
Great product from invision: headlight restoration kit, $40 from autobarn and some other auto retailers, comes with all the right sand paper, chemicals, cloths, gloves and the UV protectant.
My V35s headlights were yellow as when i bought them, dealer buffed them to clear and within another week they were back to yellow. Tried this product after being recommende it from a fellow V35 owner and they have never been yellow since.
The maguires one is crap to be honest. Cleans them up and turns yellow a fortnight later its also ironic that i has a picture of a V35 as the demo car on the bottle.
Edited by Howaitonaito
  • 8 months later...
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
